0 Pushrod hitting tube
Last Post: DR DICK
0 Q cams in 73 xlh ??
0 need help with 68 XLH
Last Post: DR DICK
0 Track Bike Build
Last Post: Dusz
Last Post: lehel
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
0 HSR idle mixture screw
Old 27th January 2021
roccus's Avatar
roccus roccus is offline
Sportster/Buell Model: XLH 1100
Sportster/Buell Year: 1986
roccus is an unknown quantity at this point
Default Gen Light stays on
I have an 86 1100. The gen lamp stays on even though the gen is putting out. The gen lamp does not seem to appear on the schematic for this bike in the factory manual. Is this light controlled by a relay somewhere? Where this lamp does not show on the I can't just follow the path to what regulates this lamp. It comes on as it should long with the oil lamp but then when I start it the oil lamp goes off as it should but the gen lamp stays on....
Early 1986 XLH 1100
rejeanprimeau's Avatar
Your generator diode is out of each, the light stay open.
Old 28th January 2021
roccus's Avatar
Thanks for your reply...... Bad diode? Even if the gen is putting out 13.8V?
The diode in the idiot light circuit.
Evo model Sportsters DO NOT have a GEN light (nor a generator), nor any light to indicate the Alternator/Regulator is working properly...
The indicator lights are:
R & L Turn Signal (When ON)
Oil Pressure (When Low)
HiBeam Headlight (When ON)
Neutral (Transmission Position)
No Generator Light...
So, which indicator light on your 1986 is staying lit? Color? Position?
Can you post a picture?
Explore The Sportsterpedia - An XLForum Information Resource!
super +1 mr. lax
neutral light if not in gear and when in gear, short to ground via the wire or switch.
http://xlforum.net/forums/archive/in...t-1205686.html
super +1 mr. lax
Here the answer.
Old 29th January 2021
roccus's Avatar
Hmmm.... maybe some swapping was done back when but it has the usual style headlight cover on it with an oil light and the gen light like this... https://www.ebay.com/itm/HARLEY-DAVI...MAAOSwfYpfEhBO
roccus's Avatar
While I have you guys here... another question... I am thinking about changing the exhaust, it has what appears to be stock now with the cross pipe that goes between the front and rear pipes... is it true this adds horse power and if you put an exhaust set up with out the cross pipe you loose horse power???
Old 30th January 2021
this would be a GOOD "?" for mr. hammer
every exh sys has +/-"s
the stock is pretty good for what it is as hd spent some coin in developing it, however, we are NEVER satisfied with just so. that said, ALL parts MUST play nice or not at all, just eye candy.
i run a modified 2001 sport and 1st went with drags and a lot of tinkering to get it to run good, still had a dip. i now run the danmoto highwayman and it really brings out the upper rpm power. each machine is its own, research, research and you guessed it research some more.
wrong item=less outcome!!!
