0 Starter Relay?
Last Post: speedyrette
Last Post: 99-883-c
0 1982 rubber oil hoses
Last Post: Gravitas
0 33.4mm fork bushings
Last Post: Staffords
0 help with stuck engine
Last Post: motorfish
0 Oil leaking :-(
0 HELP!!! 2019 HD Iron 883
Last Post: Mr Dream Merchant
Last Post: iBloke
0 Dunlop K81 Roadmasters? Anyone?
Last Post: ZTatZAU
0 Exhaust question
0 Electrical problems.
Last Post: Gravitas
Papatony, chedd (76), Nevar (71), nrbase (69), Smokin-Smitty (64), kbfarkas (62), Irondreads (52), Tim97509 (51), CCM0021 (50), wandrur, bikerusn5 (38)
  #151
Old 30th July 2016
buzzard buzzard is offline
Other Motorcycle Model: Honda Valkyrie
Other Motorcycle Year: 2014
buzzard is a glorious beacon of lightbuzzard is a glorious beacon of lightbuzzard is a glorious beacon of lightbuzzard is a glorious beacon of lightbuzzard is a glorious beacon of lightbuzzard is a glorious beacon of lightbuzzard is a glorious beacon of lightbuzzard is a glorious beacon of lightbuzzard is a glorious beacon of lightbuzzard is a glorious beacon of lightbuzzard is a glorious beacon of light
IXL2Relax
Thank you sir!
If I've got the wrong resistance that would explain the problem, I was pretty sure the wiring set up I had was correct. I'll get some 6 ohm-50w resistors today and give them a try.
buzzard
Old 30th July 2016
sportsterdoc's Avatar
I would expect the 4 ways to work without the resistors, verifying that all your wiring is otherwise correct. The exception would be extremely low wattage LEDs.
Old 7th August 2016
A big thanks for the help identifying the problem.
Ordered and installed 2-pair of aluminum cased 6 ohm resistors and the TS works great.
Great forum and even better people.
Old 7th August 2016
Glad you got it running - thanks for updating the thread...
__o~~o__
IXL2Relax
Old 7th August 2016
barry jubber's Avatar
barry jubber barry jubber is offline
Other Motorcycle Model: T140 Triumph Bonneville
Other Motorcycle Year: 1981
barry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to beholdbarry jubber is a splendid one to behold
I used a load balancer fro Custom Dynamics. Plug and play with no need to alter wires. Works great and does not get hot.
Old 7th August 2016
Congrats!
Old 7th August 2016
Heat is only generated when the circuit is energized...while signals are flashing.
Old 7th December 2017
JensWest JensWest is offline
Sportster/Buell Model: XL1200C/XLH1200
Sportster/Buell Year: 90s
JensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to beholdJensWest is a splendid one to behold
Thank you so much Scooter_Trash!
So, if I were to replace only the rear 21 W turn signals with LEDs, am I correct if I wire a resistor of > 20 W and ~ 7 Ohm in parallell with each one of the LEDs?
R = U^2/P => U^2 = 12^2 = 144
P = W difference = 21 W - LED W = ~ 20 W
=> R = 144/20 = ~ 7 Ohm
If I then were to replace both front and rear 21 W turn signals with LEDs, I assume that I could just wire a 20W/7Ohm resistor in parallell with each one of the front LEDs as well. Am I correct?
BUT, in the case of LEDs front and rear, could I just wire a > 40 W and ~ 3.5 Ohm resistor in parallell to EACH SIDE (left front and rear/right front and rear)?
> 20 W + > 20 W = > 40 W
1/R = 1/R1 + 1/R2 = 1/7 + 1/7 => R = ~ 3.5 Ohm
You got the right idea - but implementing some non-typical resistor is quite unnecessary - As previously suggested, using 6-ohm, 50W resistors (which are very common) will accomplish the job to be done...
Why would you want to make it more complicated than necessary?
IXL
2 Relax
>>>> My Build & Ride Reports Are Here <<<<
Reference the Sportsterpedia
A FREE XLForum collection of technical info & advice
IXL
2 Relax
Thank you for your reply.
I've actually ordered 50 W/6 Ohm resistors (and 25/8 and 10/10 also, since I'm not sure about which W I'd go with), since I reasoned that it's close enough.
Although, I was more curious about my assumption about the "one resistor per side", since I'd prefer to have only 2 resistor, instead of 4, to "hide away".
