0 HSR idle mixture screw
0 First start question
Last Post: Jaime1840
0 It's Glamazon's Birthday!
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
  #71
Old 21st May 2012
speedyracing11's Avatar
speedyracing11 speedyracing11 is offline
Sportster/Buell Model: sportster 883
Sportster/Buell Year: 1988
speedyracing11 is an unknown quantity at this point
I have the grounded flasher in mine and all 4 blink at the same time.What is up with that.
Old 23rd May 2012
DOM!'s Avatar
DOM! DOM! is offline
DOM! is an unknown quantity at this point
Biketronics solid state worked great on my 01. No need to worry about hot resistors or not being able to leave your hazards on for a long time.
Old 19th April 2013
kacperix's Avatar
kacperix kacperix is offline
Sportster/Buell Model: xlh883
kacperix is an unknown quantity at this point
So im another victim of LED confusion. Just got these nice small rear indicators with leds in them. (front indicators untouched) so after reading this i decided to go with installing resistors. my question is on installing it. Just to make sure i do this right and dont screw things up, i need a 10 Ohm resistor? and will it still work if i have standard front turn signals? I know its not the brightest of questions but really want to make sure.
Old 19th April 2013
dfgtye dfgtye is offline
Sportster/Buell Year: 1982
dfgtye is an unknown quantity at this point
I got mine figured out. Led in the back mini lights up front. The details are in this post
http://xlforum.net/forums/s....php?t=1445639
Old 24th September 2013
Ramzilla's Avatar
Ramzilla Ramzilla is offline
Sportster/Buell Model: 883R(1200 now)
Sportster/Buell Model #2: Ironhead Chop
Sportster/Buell Year #2: 1975
Other Motorcycle Model: CB500 Molded Chopper
Other Motorcycle Year: 70's
Ramzilla is an unknown quantity at this point
I need some help with mine. I just bought the bike not long ago and PO had installed an LED integrated tail/signal light but had no front signals. No flashing at all. I installed a set of mini bullet turns on front and one of these equalizers http://www.ebay.com/itm/321201754454...84.m1423.l2649 I still have no flashing at all. All lamps will light up solid. I did notice that the taillight uses a common ground for the entire light and does not have separate signal grounds. PLEASE HELP ME! I need signals to get it inspected.
A 4 liter V8 eater's Avatar
Sportster/Buell Year #2: 1999
I got the badlands unit, its plug and play.
http://www.badlandsmotorcycleproduct...cts/BETCSM.htm
agoristmike agoristmike is offline
Sportster/Buell Model: 883 Iron
agoristmike is a name known to allagoristmike is a name known to allagoristmike is a name known to allagoristmike is a name known to allagoristmike is a name known to allagoristmike is a name known to allagoristmike is a name known to allagoristmike is a name known to allagoristmike is a name known to allagoristmike is a name known to allagoristmike is a name known to all
I installed some LEDs from autozone into my tail lamps on my iron, work like a champ, I think they blink a bit faster than normal, but...whatever.
Front signals are still old incandescents.
Old 29th March 2014
T-reXL1200's Avatar
T-reXL1200 T-reXL1200 is offline
T-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant futureT-reXL1200 has a brilliant future
This thread is almost as old as I am, but great info! If anyone is still reading, how are the EFI sportsters different? I'm assuming the flasher is a part of the ECM? If so, it seem like a logical solution to program the ECM to adapt to LEDs. I installed LED flashers, and they flash super fast (which I've heard is the ECM notifying you that something is wrong). Should be noted that I'm only running flashers in the front, just running/brake lights in the back. Can anyone shed some light on this? I don't much like the super fast flasher.
Old 31st March 2014
Cosmo Kramer's Avatar
Sportster/Buell Model: 1200N
It has nothing to do with the ECM (engine control module) and everything to do with the TSM (turn signal module). The TSM is designed to expect a certain range of amps being drawn by the lights. When a bulb burns out that changes the amp draw and the TSM blinks fast (instead of not blinking at all like the older models did) to notify the rider that there is an issue.
Cosmo
Old 31st December 2014
DBH's Avatar
DBH DBH is offline
Sportster/Buell Model: 883/1250 Sportster
Sportster/Buell Year: 03
Sportster/Buell Year #2: 1977
Other Motorcycle Year: '02
DBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond reputeDBH has a reputation beyond repute
Ok so a few yrs ago I did some LED's on the rear end and used 2 10watt, 10 ohm resistors, 1 for each side, cool all worked great. I am now installing a front set of LED's, so captain logic here decides i just need another 10ohm 10watt resistor on each side and all should be good, Wrong, won't work, What do I need to do?
Life should NOT be a journey to the grave with the intention of arriveing safely in an attractive well preserved body, but rather slideing in sideways, "Jack" in one hand and a beer in the other, body thoroughly used up, totally worn out, screamin "Holy shit what a ride!"
Life is all about "Faster horses, Younger Women, Older Whiskey, And more Money" Thank you, Tom T Hall
“A free people ought not only be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them. Which would include their own government.”
– George Washington
