0 It's Glamazon's Birthday!
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
Last Post: lehel
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
  #461
Old 5th August 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Yep. That's pretty much it. The umbrella does rest on very edge even with the spacer in tact tho.
Old 5th August 2019
Hippysmack's Avatar
Thanks.
I dropped the umbrella down.
I just want to present an understanding of how it works.
edit:
I created a sub doc under Aftermarket Breathers on the main CC pressure page for the Hayden valve.
"Dissecting the Hayden KVP38 Crankcase Breather Valve"
http://sportsterpedia.com/doku.php/t...ref:engmech04a
Also I've included bustert's testing on the main page.
http://sportsterpedia.com/doku.php/t...essure_testing
Old 5th August 2019
dieselvette's Avatar
so it would have sucked the water into the flywheel compartment but the larger tube seemed to handle it in stride.
I was thinking of using oil, then if it gets sucked in no worries.
Shouldn't the liquid damper the hammer some?
Liquid doesn't, but air does. So how about use oil and put a valve right at the connection, tube uphill from there. Fill tube with oil and see which way it goes when you open the valve.
____________________________________________
FIND HELP WITH YOUR SPORTSTER HERE: http://sportsterpedia.com/doku.php
If men can build it, men can fix it. - Tim Allen
2004 1200 Roadster Custom-Electra-Glide-Sport-Touring-Edition
SE air cleaner w/venting routed outside a/c
Supertrapp 2:1 pipe - usually 20 discs w/closed endcap
Stock CV carb w/ Yost tube + DS idle mixture screw
Cycle Electric 38A charging system
TC88A ignition
0.030 head gasket, zero deck-height
Hammer 570 cams
Bronze oil pump gear, updated oil pump
30-tooth HDI belt sprocket (137-tooth belt)
Old 5th August 2019
Actually if we could get 60Gunner to do my proposed test, known bad breathers vs good breathers, maybe we find out it's an applicable straightforward test.
If you don't have a timing plug fitting, tee into the tank vent line?
Old 5th August 2019
Hippysmack's Avatar
That's a good question.
Nothing more oil laden than the oil tank itself.
Disturbing the air leaving it might upset the tank?
It'd be worth trying I suppose.
This idea is new to me. But if I didn't have a timing plug, I'd be prone to tap the cam cover.
I know, I here it coming.
Old 5th August 2019
i will have to go get the model of the dwyers manometer.
if you use anything diff, you will need to have a calibrated scale because diff fluids have diff specific gravity.
when i was running the control room on semi-submersible drilling rigs, we used mercury units because the heavy metal was a dampener of sorts when you consider the rig constantly moving. they monitored ballast level in the tanks 80 feet down from the texas deck.
cannot find a good brass needle valve here anymore so i had to use a B&S inline fuel cut off valve, china plastic.
in reality, the tube holds so little water, would be no issues. as far as color, i used food color so hot pink could happen. dwyers does make their own fluid with a florescence additive to heighten the contrast, my bottle leaked it all out.
need to look at the cases but a hidden or reversible method need to be made.
for grins and giggles, using a cam follower block bolt made for a tap off to the chest, probably would have to drill a small hole in the case if the hole is blind but the hole only needs to be very small, will have to see what i used. this way, replacing with the stock bolt covers everything up. if it weeps, a little teflon on the threads but myself, add o-ring groove under the head.
Old 5th August 2019
Ebay - search for 1/4 brass needle valve.
Or, I have tons of tubing, fittings, etc if anyone needs something you can't find I will send for the cost of shipping. Won't be home until next week though.
Old 5th August 2019
Hippysmack's Avatar
That's what I was wondering since the instruction sheet specifically said dyed water or mercury only.
As far as the liquid dampening, it's not compressibility but non compressibility I was thinking of.
I was thinking the more dense the liquid, the harder it is to affect (move) it.
Si I figure that would be a factor in operation.
I don't have a problem tapping into the engine.
But, it'd be nice to have an easy way to attach the unit for those without a timing plug.
So the valve is needed to regulate flow to get around the initial surge or during entire testing?
Old 5th August 2019
60Gunner's Avatar
Never tee into the tank vent line. I'll test good vs. bad breathers if someone wants to send me a set of good ones.
Old 5th August 2019
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
A restriction damps the fluctuations. A needle valve makes a nice adjustable damper. It's a full time thing. If a small diameter tube fed the gauge or manometer we'd shove the smallest pilot jet we had in it. Sometimes two if one didn't damp enough.
