Last Post: mrmom9r
Last Post: fafcpa
0 need help with 68 XLH
Last Post: mrmom9r
0 Oil pressure switch
Last Post: Edster
Last Post: Fivecats
0 What oil temp do you run
0 HSR idle mixture screw
0 Gear and brake linkage
Last Post: Hardtail28
0 Front deflection
0 Off Road Lights
0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 First start question
Last Post: Fivecats
Last Post: Turbo Sporty 48
  #471
Old 5th August 2019
Hippysmack's Avatar
Hippysmack Hippysmack is online now
Ok, that makes sense.
I've never used one so lots of dumb questions.
Old 5th August 2019
dieselvette's Avatar
To be clear, this is a pressure test and not a flow test. It is imperative that the fluid height be enough to prevent air from coming in/out - the fluid acts as a moving "air blocker" and this apparatus does not act like a second vent. Hence to need to buffer it with some kind of restriction, lest a sudden pulse blows the tube empty. 60Gunner do you suppose in this scenario, the tank vent line could be tapped into?
Depending on the amount of restriction (and air volume in the tubing etc) connecting the manometer, you will get different results in terms of fluctuations or pulsing. But in any case you'll get an overall average of CC pressure/vac which is repeatable with any manometer setup (assuming the same fluid). Ideally you would open the needle valve as far as possible, without your manometer going crazy.
____________________________________________
FIND HELP WITH YOUR SPORTSTER HERE: http://sportsterpedia.com/doku.php
If men can build it, men can fix it. - Tim Allen
2004 1200 Roadster Custom-Electra-Glide-Sport-Touring-Edition
SE air cleaner w/venting routed outside a/c
Supertrapp 2:1 pipe - usually 20 discs w/closed endcap
Stock CV carb w/ Yost tube + DS idle mixture screw
Cycle Electric 38A charging system
TC88A ignition
0.030 head gasket, zero deck-height
Hammer 570 cams
Bronze oil pump gear, updated oil pump
30-tooth HDI belt sprocket (137-tooth belt)
Old 5th August 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
It will take oil with it.
Old 5th August 2019
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Based on what?
You'd be tapping a vent line and the only "flow" would be the amount you see the manometers' column moving.
Old 5th August 2019
the slack tube is a dwyers 1723-72 which will measure to 72" of water.
orifice size is based off piston diameter
my chosen size was 7/64
interestingly, there was no oil mirgration through the orifice.
to be honest, i see no issues with using the c/c to bag line since there is no flow out the manometer. only issue i can see is if there was oil being pushed through the line.
you could even modify an oil cap, this is done on automobiles, matter of fact, cooper has an article for doing so on their r5 engines.
the issue here is that the further from test point, time factors in travel effects readings with larger diameter lines adding more skew.
they do have handle bar mounts that will hold a vac/press gauge, they even have hand held digital units that can record. dwyers sells them.
Old 5th August 2019
60Gunner's Avatar
Originally Posted by Tomcatt View Post
Based on what?
Based on numerous accounts of people trying to vent there. Go ahead and tee there.
Old 5th August 2019
Dazed & Confused
Yep, a gauge/meter taped to the bars could be seen as you ride so you could see pressure/vacuum under real conditions. Just need an "inches of water" gauge with a useful range that will read pos and neg pressure. Then damp it well enough to not kill the gauge. Big diameter analog gauges with needles can be easier to read.
Old 5th August 2019
Dazed & Confused
We're not talking about venting, just a pressure tap. Two different things. Now you've read that on the internet too.
Old 5th August 2019
I've used an automotive vacuum gauge, usually used to measure intake manifold vacuum, to measure crankcase vacuum on my old ironhead. It will read negative and positive pressure.
For what you're trying to find out, wouldn't that work just as well as a manometer?
Old 5th August 2019
Hippysmack's Avatar
Can't take him anywhere.
Judging from the balloon test, Aaron's and bustert's testing, there shouldn't be any reason you couldn't use the vent line.
If it turns out bad, you may have other problems to address anyway.
The vent mods folks do there are different in that air is allowed to vent.
As mentioned, as long as the water is not blown out, it's just a pressure test point.
No different than installing a pressure gauge there.
I've got to get around to getting a flow meter as well.
