0 Carb ???
0 It's Glamazon's Birthday!
0 Deeded Electrical
Last Post: Ark OB
0 Dragging clutch
Last Post: Ark OB
0 What oil temp do you run
0 need help with 68 XLH
Last Post: andy2175m4
Last Post: toe
0 Mainshaft Oil Seal Leak
Last Post: mac93
0 For Sale 2003 XL883C 1200 Conversion
Last Post: webrehm
Last Post: Fivecats
0 2021 Iron Butt Rally
0 Indicators not flashing
0 First start question
Last Post: 72HOGXLCH
  #751
Old 22nd August 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
tooooo bad, tooooo bad, you do not have a trap door
the speedo is history when dropping out of 3rd.
I don't normally pay a whole lot of attention to the speedo. I use to use it more as a tach but I've gotten pretty good at knowing rpm by feel but I use 2nd and 3rd if I want to know pin point an rpm by speed/gear.
rocketmangb's Avatar
Needles and Needle Jets,figure out how many combinations there is !
Yall will shit !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Hippysmack's Avatar
got any extra to sell??
i am always a day late and a dollar short plus a glutton for punishment. i need a drop axle for my wagon.
I think I'm about done with my old ones.
Need em? I've already split them for pedia pics.
Free to a good home.
Hippysmack's Avatar
Yall will shit !
I can only imagine. Actually it's hurts to imagine.
ok
4 needles
5 grooves each
5 needle jets
ok
4 needles
5 grooves each
5 needle jets
Hippysmack's Avatar
Yeah but which combination works the best.
We wont even discuss the main jet pilot jet thing !
Hippysmack's Avatar
I'm working on the butterfly carb in the pedia... seems a lot more simple.
60Gunner's Avatar
The needle jets aren't as readily available either. They allow tuning twice as fine as just raising or dropping the needle a groove. Im running a 96.5 needle in clip position 2.5.
Isn't the different combinations something like 560? That's fine tuning.
People with EFI aren't likely to be as in tune with the feel of their motor.
Remember when just about everyone ran the same jets in the cv? Or close to it anyway. Just can't fine tune that carb nearly as well. I sure don't miss the vacuum operated slide and it's delayed reaction.
