Last Post: 4cam
0 help with stuck engine
0 First start question
Last Post: mac93
0 Starter Relay?
5 Rethinking 1250 Build
Last Post: Desertfox
Last Post: Fivecats
Last Post: lehel
0 Sportster R.I.P.
Last Post: LLOYD883
Last Post: LLOYD883
Last Post: LLOYD883
Last Post: speedyrette
Last Post: 99-883-c
0 1982 rubber oil hoses
Last Post: Gravitas
1275, big bore kit, custom build, custom oil tank, lithium ion battery
  #401
Old 16th April 2021
rocketmangb's Avatar
I know what they look like
Im just saying what happened to me
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 16th April 2021
BestCoastXL's Avatar
BestCoastXL BestCoastXL is offline
Disassembly Specialist
Sportster/Buell Model: XL883L
Sportster/Buell Model #2: XL883L/1275
BestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond reputeBestCoastXL has a reputation beyond repute
So shopping around on the internet is cool and all but when your local hoses and fitting Independent has exactly the right fitting as well as something cool for a future tank mod project..... well, that's just dandy.
The 1/8MNPT x1/8FNPT low profile fitting is exactly what I needed to give me all the clearances. If your local doesn't have them, Lowbrow does.
I'll be drilling out the male end to 1/4" to keep the flow diameter as wide as possible without affecting the fitting's ability to make a seal in this non-pressurized oiling system. The rest of the oil lines wil be 3/8" I.D. or 6AN.
These other bits are Scully Flanges for use in a winter project.
Itty bitty sight gauges fit in them and when I order a fresh tank, (because bringing a welder a tank that's had gas in it is dangerous and kind of a dick move unless properly purged) then I can have 3 of these along the tank to get a quick and easy sight ref on fuel state. I'll also be relocating the Motoscope mini to a vertical position along the back of the new tank. The scope has a setting to display readouts vertically.
Old 16th April 2021
wedge's Avatar
wedge wedge is offline
These other bits are Scully Flanges. Little Bitty sight gauges fit in them and when I order a fresh tank, (because bringing a welder a tank that's had gas in it is dangerous unless properly purged) then I can have 3 of these along the tank to get a quick and easy sight ref on fuel state.
One of my neighbors a few shops down from mine used to weld a lot of gas tanks, and he filled them with gasoline. According to him, as long as there is no air in the tank, it will not explode. He welded a hole in the bottom of my tank on my shop truck with the tank fully loaded and I stood right there while he did it. It did not explode.
Old 16th April 2021
Steve9's Avatar
Steve9 Steve9 is online now
Sportster/Buell Year #2: 1981
Other Motorcycle Model: FXDC
Damn that sounds scary!
Like holding a high-power line if you are not grounded......no thanks
Steve
'03 1250 NRHS stage two Lightning heads, 536, mik 42
'01 Cyclone
'13 FXDC 96" stock
Old 16th April 2021
YEP - Gasoline is explosive as a gas (vapor) but not as a liquid...
http://wyomingworkforce.org/_docs/os...flamliquid.pdf
Still --- --- Not my idea of safety...
For Sportster Tech Info:
Old 16th April 2021
Yeah.....don't think I'll try that.
Old 16th April 2021
Sportster/Buell Year #2: '03
?? but it's the path to ground that completes the circuit.birds can sit on a high voltage line without being fried because they're not touching ground.
Old 16th April 2021
wedge's Avatar
Ya know, I don't think I would either, but this guy is a professional welder and he does a lot of exactly that. I stood there as he rolled under my truck and welded it up. Can't say I wasn't expecting a quick ride to the hospital, but it was just fine, and the tank hole was fixed. One thing I don't remember though, and it's probably important, is weather the cap was on the tank or not. I topped it off right to the filler with a can so there could be no air in the tank.
Old 17th April 2021
wedge's Avatar
He also said, NEVER weld on an empty tank, or even a tank filled with water. He said you can never get the tank clean enough to trust it. It seems he was going on a lot of experience and knowledge of the subject.
Old 17th April 2021
John Harper's Avatar
Sportster/Buell Model: 1250
Sportster/Buell Year: 1991
I've heard of people killed welding on top of old 55 gallon drums.
John
