0 First start question
Last Post: Jaime1840
0 It's Glamazon's Birthday!
0 Q cams in 73 xlh ??
0 HSR idle mixture screw
0 "S" model specific Q&A
Last Post: Edster
5 How do I increase sag ?
0 Track Bike Build
0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
0 Range With EFI 3.3 Gal Tank
Last Post: Mike1nw
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
Old 2nd June 2021
d10221's Avatar
d10221 d10221 is offline
Sportster/Buell Model: XL883N
d10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to beholdd10221 is a splendid one to behold
Default Should I take any special measure to keep the bike in storage for 2 months ?
Disconnect battery ?
Empty fuel tank ?
None ?
BTW: here is cold , but not that cold ... no freezing
Thanks!
17' XL883N (South Africa) | "I told you ... I don't know what I'm doing"
Old 2nd June 2021
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
Fuel stabilizer
Battery tender if you like. Disconnect might be good, I hear the new ones have mucho drain even while off
Steve
'01 Cyclone
'13 FXDC 96" stock
Old 2nd June 2021
d10221's Avatar
Thanks Steve9 , that was quick
Old 2nd June 2021
Raise the tires of the ground to keep from getting hard spots in the rubber?
Old 3rd June 2021
Consider changing out the blinker fluid, synthetic is now available and lubing the muffler bearings should do it for you. Let the bonding continue.
I.B.A.#26543,
Old 3rd June 2021
Andy56 Andy56 is offline
If you do not have access to a battery tender then disconnect the battery.
There is cold and there is cold. Over the winter here in the UK I do not use fuel stabiliser and the bike was not run for around two months. It started up fine when I did eventually get to ride it.
I did fill the tank and mostly when the temperatures are low keep the tank filled.
Old 3rd June 2021
I have a 2017 bike. This year is its 4th birthday. With that in mind it will require a 20,000 mile service regardless of how many miles are on the clock.
Has your bike been serviced per the FSM? That will be more telling as to whether it will be okay after not running for just 2 months.
To add to above we have E5 petrol here, it will soon be E10. That might make a difference to petrol life.
Old 3rd June 2021
Highly-Dangerous's Avatar
Definitely!!!!!!
Mine has been stored for almost 6 months..... I did not have time to prepare anything before we got separated..... I just went to pick her up last week..... there she was... patiently waiting for me.... she did not hesitate a second to start purring as soon as I touched her....
Old 3rd June 2021
DEEP DIVER's Avatar
Sportster/Buell Year: 1984
Sportster/Buell Year #2: 1993
Other Motorcycle Year: 1984
Or just give her to sportsterpaul, he'll look after it for you.
Blue belt in Serious tea drinking. :)
Old 29th July 2021
JunkyardDog JunkyardDog is offline
Other Motorcycle Model: Kawasaki Vulcan 750
Other Motorcycle Year: 2002
JunkyardDog is a splendid one to beholdJunkyardDog is a splendid one to beholdJunkyardDog is a splendid one to beholdJunkyardDog is a splendid one to beholdJunkyardDog is a splendid one to beholdJunkyardDog is a splendid one to beholdJunkyardDog is a splendid one to beholdJunkyardDog is a splendid one to beholdJunkyardDog is a splendid one to beholdJunkyardDog is a splendid one to beholdJunkyardDog is a splendid one to behold
Slightly over inflate the tires, connect a battery tender to it. I don't know what kind of gas you have, if you have ethanol gas you have a problem. I don't know how to drain the gas out of the tank of an EFI bike. I live in Arizona USA, and we have ethanol gas. It will start to break down and do damage in less than 2 months. I have a 2006 1200L, and I replaced the vacuum petcock with a manual one so I can drain the gas out. Because summers here are so hot (120 degrees F) my bike gets ridden very little during the summer. It sits a lot. I have a 4.5 gallon tank. I only ride the bike maybe 50 miles a month, at night. Not enough to keep fresh gas in it. So once a month I drain all the gas I can get out of the tank (I remove the fuel line from the petcock to the carb, and drain it into a 5 gallon gas can, and pour it into my car. I then refill the gas can with fresh gas and refill the tank with it, then run the bike long enough to get the fresh gas into the carburetor) I do this once a month all summer. Sounds like a pain, but I have seen the damage ethanol can do to anything it touches. It's a lot cheaper and less work than repairing ethanol damage. Ethanol would likely damage the in tank fuel pump on an EFI bike. If there is any way to drain the tank, do it. But don't use the fuel pump to do it, because running the pump until the tank is empty and the pump is running dry will also damage the pump. Hopefully you don't have ethanol gas.
"I refuse to believe in a risk free society where the thrill of living is traded for the safety of existence." — Nick Ienatsch
