0 why you can't be seen
0 need help with 68 XLH
Last Post: mrmom9r
0 Oil pressure switch
Last Post: Edster
Last Post: Fivecats
0 What oil temp do you run
0 HSR idle mixture screw
0 Gear and brake linkage
Last Post: Hardtail28
0 Front deflection
0 Off Road Lights
0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 First start question
Last Post: Fivecats
Old 30th June 2021
Mr.Rowdy's Avatar
Mr.Rowdy Mr.Rowdy is offline
Mr.Rowdy is an unknown quantity at this point
Default Finding problems after top end and cams...
So after I did the 1275 I wasn't happy with the stock D cams AND I was having a low oil pressure light after it got hot and at low rpms.
I installed Reaper cams and a bronze oil pump gear and a new oil pressure switch. It runs good but refuses to get past 5500-5800 rpms despite my Dyna2000 rev limiter being set at 6500.
I kept increasing the main and the wall kept getting softer but it still wouldn't rev past 5800 and would surge at that rpm. I also noticed that the front cylinder plug was whiter (leaner) than the rear AND I had a top end tapping.
I narrowed the tapping down to the front cylinder intake. A compression test shows 155 psi front and 165 psi rear with the engine cold. A leakdown shows both valves sealing on both cylinders and a minimal amount of blowby through the timing plug at TDC on both cylinders. Again, engine was dead cold.
So given the lean front cylinder, surging, lack of revs, tapping noise and lower front compression I am guessing that I have a collapsed front intake lifter. I didn't replace them when I did cams.
Does my evaluation seem sound here? Next step it to remove the front rocker boxes and inspect that front intake lifter.
Old 30th June 2021
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Will the engine free rev past 5,800? I'd be wondering if the ignition module had actually accepted your increase to 6,500 rpm.
If you're pulling rocker boxes I'd also check for broken valve springs.
Old 30th June 2021
Mr.Rowdy's Avatar
I did not free rev the thing to see. I've changed the rev limit up and down and nothing. I tore it completely down and have found nothing but signs of rocker shaft knocking on the front intake. That was probably the noise. So I will replace lifters and valve springs and put it back together. Running out of ideas
Old 30th June 2021
You might drop a dime to the Dyna2000 guys for their input?
I.B.A.#26543,
Old 1st July 2021
Dazed & Confused
Originally Posted by Mr.Rowdy View Post
...I've changed the rev limit up and down and nothing...
If you set the limiter below 5,500 and it still revved to 5,500/5,800 I agree with sportsterpaul that a chat with the folks at Dyna2000 would be appropriate. Seems like getting the module to accept rev limit changes has come up before.
Old 1st July 2021
Mr.Rowdy's Avatar
I've spoken to the Dyna guys. The lowest rev limiter setting is 6000. I've put the stock ignition module in and get the same thing. I've tried limiter setting of 6000, 6500 and 7000 with no change.
Old 1st July 2021
Dazed & Confused
Then you might pull the cam chest cover and check the cam timings while the rocker boxes are off. It's easy to miss the alignments by a tooth. It could also account for the front/rear cranking pressure difference and the ticking.
Old 1st July 2021
This may seem like a dumb question but it does happen.
Is the throttle plate opening all the way?
After trying 2 different ignition modules the cause is probably not the ignition. But something is choking it. Valve float can limit your RPMs but it seems that would be noticable?
Old 1st July 2021
Mr.Rowdy's Avatar
I've checked cam timing and the throttle plate.
Old 23rd July 2021
seajay's Avatar
seajay seajay is offline
Sportster/Buell Year: 04
[QUOTE=Mr.Rowdy;5902532]
With only 250 miles, the above does not jibe with Hammer's break in instructions.
