0 Exhaust question
0 Bassani Baffle Supplier
5 Rethinking 1250 Build
Last Post: xena
0 First start question
Last Post: Jaime1840
0 Timing, static or strobe?
0 Starter Relay?
Last Post: xena
Last Post: Andy56
0 33.4mm fork bushings
Last Post: 4cam
0 help with stuck engine
0 1988 1200. Unable to get oil pressure. New pump, new filter, new pipes, new oil.
Old 22nd July 2021
bobber58 bobber58 is offline
Sportster/Buell Model: XLH bobber
Sportster/Buell Year: 1964
Sportster/Buell Model #2: XLH
Other Motorcycle Model: 883 Iron
Other Motorcycle Year: 2010
bobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to allbobber58 is a name known to all
Default Having trouble finding bolts
So I'm working with a Knuckle/Pan rear drum brake. The stock style 3/8-20 bolts won't work with my wheels (custom Invader). The head on them is too big to allow them to go into the holes. So I need 3/8-20 x 1 socket head or button head cap screws (preferably chrome or stainless, but beggars can't be choosers) and cannot find a single source for 3/8-20 bolts anywhere. Anybody have any leads on where I may find these? Thanks.
Old 22nd July 2021
Never heard of a 3/8" x 20 thread, not at all common. Not listed in my machinists handbook.
Common 3/8 sizes are 16 and 24 TPI
Old 22nd July 2021
Try:
https://www.google.com/search?q=3/8-20+bolt+chrome
https://www.google.com/search?q=3%2F8-20+mcmaster+carr
For Sportster Tech Info:
Old 23rd July 2021
Yes, it's not common, but it is what Harley used on early rear drum brakes. Why, I have no idea. It's a British thread from what I can find.
Old 23rd July 2021
All they show is a lead screw. No bolts.
Old 23rd July 2021
Looks like the designation is 3/8" BSF (British Standard Fine)
https://www.asmc.net/3-8-20-x-1-2-ft...l-black-oxide/
Old 25th July 2021
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
It's probably not a British thread form. Brit threads are a 55 degree angle on the V of the thread. US are 60 degree. My guess is Harley made their own special 60 degree 20TPI thread so you could NOT use a standard US socket head cap screw in there in place of the original bolts that had a special chamfer on the seating edge of the head to locate the wheel and to stop the bolts working loose.
The wheel hub had matching chamfers on the bolt holes. If your custom wheel has these, you would be best to machine down the original bolts to fit in the space available. Otherwise machine off the chamfer to fit your custom wheels and use Loctite or safety wire to stop them coming undone.
But BSF bolts will fit if you absolutely have to. The two different angle threads will usually screw together ok as they are made with plenty of clearance on mass produced threads. As long as diameter and TPI are the same you are usually ok. No great loss of strength or security involved. Some maybe but not great.
Harley made a lot of oddball threads pre-1970s as they had the machines to make all their own fasteners and parts threads rather than buying in standard issue. But they all used the standard 60 degree thread roller tools.
Old 25th July 2021
jeffro57 jeffro57 is offline
Sportster/Buell Model: custom
Sportster/Buell Year: na
jeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud ofjeffro57 has much to be proud of
go to tractor supply
Old 26th July 2021
Andy Hog's Avatar
Andy Hog Andy Hog is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: 1964 Triumph 3TA
Andy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant futureAndy Hog has a brilliant future
Can you not just tap in a metric thread & replace with metric bolts, or are you a bolt specific type of guy?
Old 26th July 2021
Are those the bolts with the tapered shoulder like lug nuts?
https://cyclevintagee.com/replaces-h...-part-43530-35
