The Sportster and Buell Motorcycle Forum - The XLFORUMŪ
Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUMŪ > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Era Specific and Model Specific > Ironhead Sportster Motorcycle Talk (1957-1985)
0 why you can't be seen
0 need help with 68 XLH
Last Post: mrmom9r
0 Oil pressure switch
Last Post: Edster
Last Post: Fivecats
0 What oil temp do you run
0 HSR idle mixture screw
0 Gear and brake linkage
Last Post: Hardtail28
0 Front deflection
0 Off Road Lights
0 The One Who Likes Pineapple
Last Post: Fifty150
Last Post: Hopper
0 Sportster S on the dyno
Last Post: crfblur
0 First start question
Last Post: Fivecats
Old 22nd July 2021
Jaime1840 Jaime1840 is offline
Sportster/Buell Model: XL
Jaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of lightJaime1840 is a glorious beacon of light
Default Valve seats PICTURES
Hello again guys,
It seems like I have face a new challenge everyday
This time it's the valve seats, I took the heads to a shop to get new guides installed, cut new seats. I did a leak test putting some gas in the combustion chamber to see if it would trough the valve and the seat and it did in one head. I took the heads apart I found the seats like you see in the pictures, what do you guys think? Did they actually cut new seats or just did some lapping?
PICTURES:
https://postimg.cc/gallery/9QLnwV1
Old 22nd July 2021
perfesser's Avatar
perfesser perfesser is offline
perfesser has a reputation beyond reputeperfesser has a reputation beyond reputeperfesser has a reputation beyond reputeperfesser has a reputation beyond reputeperfesser has a reputation beyond reputeperfesser has a reputation beyond reputeperfesser has a reputation beyond reputeperfesser has a reputation beyond reputeperfesser has a reputation beyond reputeperfesser has a reputation beyond reputeperfesser has a reputation beyond repute
i don't see newly cut valve seats. i see filthy ports and old seats and what looks like new guides hammered in. do the faces of the valves you removed show evidence of being ground to fit new seats?
Old 22nd July 2021
randy3934's Avatar
looks like a poor lap job to me, I see pitting in the seat areas, if they were cut they would be gone.
Old 23rd July 2021
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
ericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud ofericfreeman has much to be proud of
You need to check the valve protrusion to make sure they're not sitting too far down in the seats. Every time the valves and seats are cut the valve stems stick further into the rocker boxes. There's a factory spec that if exceeded, means you need to have hardened seats installed and cut.
Old 23rd July 2021
hey, I was talking with a couple engine builders and they say the valve seats have been cut, but the job itīs not very good. the valves look fine I cant really tell if they have worked on the valves because the sitting surface has the lapping finish.
Old 23rd July 2021
Apparently when you cut seats you cut with 2 or 3 angles. It seems like they only have cut once and they didnīt do it properly. Im wondering if could just lap them my self and finish the job so they seat properly, I donīt really want to go back to that shop.
Old 23rd July 2021
I will, thanks.
Old 23rd July 2021
sometimes with cast iron heads, you will get crappy cuts. if i were to redo cast iron heads, i would install harden seats which i have in my 74ch.
can you lap it in, why sure, but for how long will it seal, hummm, a good ?
have you tried popping the valve with a rubber mallet and see it the leak is still there?
if you pull the valve, coat the surfaces with some machinist ink and install without spring and twist to see where the two seat and how wide.
these heads are iffy at best so installed height is important as it shrouds the port. you have to be careful but you can port these a little. exhaust side more important than intake.
Old 23rd July 2021
Hey,
I donīt really want to spend more money in the heads unless itīs absolutely necesary... I was thinking on taking them back to the shop or lapping them. I havent tried the rubber mallet method and I donīt have any layout dye but I guess I can get some.
Old 23rd July 2021
perfesser's Avatar
looking closer at the second photo, there are chatter marks and a discoloration on the intake valve seating surface that i would expect to be absent if they were cut properly. or at all. i would not be happy paying for someone to not do this work properly and call it done. maybe find another machinist to do a proper three angle job.
XL ForumŪ - Linson Media LLC
