0 Pushrod hitting tube
Last Post: DR DICK
0 need help with 68 XLH
Last Post: DR DICK
0 Track Bike Build
Last Post: Dusz
Last Post: lehel
Last Post: handa700
0 Gear and brake linkage
Last Post: Andy56
0 Oil pressure switch
0 Valve Stem Seal ID
Last Post: BruceM
0 What oil temp do you run
0 Clutch Spring plate poll
0 why you can't be seen
Last Post: Les59
0 HSR idle mixture screw
Old 29th October 2006
greg_cycle greg_cycle is offline
Sportster/Buell Model: Sportster 883/1200
greg_cycle has disabled reputation
Default Another oil mist problem & slobber stoppers
Greetings,
I just joined the forum yesterday. Looks like this forum has a wealth of good information.
I'm just breaking in my 1998 883/1200 conversion with Stage 1 mods (SE intake and Slip-ons), and noticed on my ride today (longest one so far circa 40 miles - lots of curvy road and hills) that I had oil coming out of the air cleaner assembly onto the side of the bike. When I got home and removed the air cleaner cover I could see oil mist being pumped out of the bike.
Thus a couple questions:
1.) Is it normal that one can see oil mist being pumped from the motor with the air cleaner can off when running the SE air cleaner assembly? I hope so since I don't want to do another rebuild.
2.) Has anyone tried the Slobber Stopper system to fix the oil mist problem, and if so did it work? I'd prefer to stop the problem at the source, versus installing a kit that routes external hoses under the bike for venting.
Thanks in advance for any help. The bike has 65 miles on the rebuild so far and had probably been through 5-7 heat cycles.
Greg
shotgun46's Avatar
Slobber Stopper system ?? what is this you speek of ?? do you have a link or more info !
Sportsters Rule ! :banana
cjburr's Avatar
cjburr cjburr is offline
Sportster/Buell Year #2: 1998
Other Motorcycle Year: 2009
Perhaps you had too much oil in the tank ??
and to the forum
My Other Toy Goes Mach 25
merc merc is offline
Sportster/Buell Model: Custom
Other Motorcycle Model: Suzuki GN400
Other Motorcycle Year: 1980
merc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond reputemerc has a reputation beyond repute
welcome to the forum.
I have routed the oil mist to a hose that terminates below the bike so any collection of oil drops just disappear there.
What is slopper stopper system?
doxbike doxbike is offline
Sportster/Buell Model: FatBob
Sportster/Buell Model #2: all gone 1200R
Other Motorcycle Model: Honda ST1300;Goldwing1500
Other Motorcycle Year: 0407
doxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of light
Merc,
How much oil exits via the re-reouted vent hose? Enough to possibly make the rear tire slick?
Cjburr has it right I think. I keep the oil level just above the fill line and have no detectable oil mist
no way--it has to be so minor that it nearly does not exist.
Many do it this way.
hey-I googled slobber stoppers
here they are:
milmat1's Avatar
milmat1 milmat1 is offline
Sportster/Buell Year: 06
I had the same basic question when i joined a few months ago. That is; how are you stopping it ? And the general answer here is there not ! Just let the crankcase pressures push it out on the ground with a hose.
Also many of the guy's here have found that it's better to leave the oil level just slightly below full!!
Myself I have had no problems with my 06.
For whatever reason : Almost every post that deals with the Oil blowby is running an SE air Cleaner !!
We have argued this back and forth here, Whether to leave it connected to some vacuum source or vent it to the ground, Or catch it in a catch can. But the main result is most of the people live with it one way or another. And by far the most effective way is to lower the oil level in your tank by a small amount.
On your newly built engine, You will likely have some extra Blowby until everything gets seated and sealed, So I wouldn't make a call until you get a few miles on it unless it's really exessive !!
Like I said I have had no problem so far, But for some reason I have trouble excepting the old "Sporty's do That"" Answer.
Old 30th October 2006
H@mbone!'s Avatar
H@mbone! H@mbone! is offline
Sportster/Buell Model: XLH883
Sportster/Buell Year: 1987
Other Motorcycle Model: Custom Shovelhead Softail
Other Motorcycle Year: 1971
H@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura aboutH@mbone! has a spectacular aura about
Welcome to the XL Forum!!
71 HD Shovelhead in a aftermarket softail frame and 87 HD Sportster XLH883
Gone Gone is offline
Gone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud ofGone has much to be proud of
check this link http://www.mklsportster.com/xloilblowbyarticle.htm it will explain the oil mist problem and how to deal with it.
