Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > GENERAL AREA > The BUY - SELL - TRADE Zone
0 73 XLH Total Power Loss
Last Post: Erikdowney18
0 Valve Lengths?
Last Post: motorhedmike
Last Post: Mike1nw
0 Cleaning carbon build-up
Last Post: vt883
Last Post: commando57
0 Gasket placement
Last Post: Billy1200
0 XR mutt race bike progress
0 Info needed on mini sumps.
0 What oils do you run in your ironhead
0 Lifters+w cams
Last Post: supermotolew
0 HF bike lift
Last Post: salmanmr
Last Post: jharback
0 Chasing Down Leaks
Last Post: ericfreeman
0 Main shaft bearing preferences
Last Post: Heff
0 Chinese S&S carbs
0 Tire pressure
0 K/n air filter,, and s/s super b long thumb screw bolts
Last Post: Rgm883
vt883, Danno, Otis_hd (70), Fisherman (69), New Girl (63), soup (58), motormyk (51), leo, UncleSmitty (43), bryguy1977
Old 29th May 2020
Sparkes's Avatar
Sparkes Sparkes is offline
Sportster/Buell Model #2: 883 53c
Sportster/Buell Year #2: 1999
Sparkes is an unknown quantity at this point
Default Slash cut drag pipes without oxygen sensors wanted
I have a 1999 sportster evo 883 53C With screaming eagle slip ons..
I’d really like a new or mint set of slash cut drag pipes instead if anyone has a set they’d like to move on 😊
Old 30th May 2020
robbie202's Avatar
robbie202 robbie202 is offline
robbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant futurerobbie202 has a brilliant future
i might actually have some i'll check
2020 KLX250
1977 GL1000
Old 30th May 2020
Sparkes's Avatar
Nice one thanks 👍🏽
Old 31st May 2020
robbie202's Avatar
Ok these don't look that new. Came off an 03 Used for 2 seasons. The camera doesn't puck it up but there is lots of small rust pitting. Also you are in the UK? Shipping would be high. Anyway here's the pic.
Sent from my SM-G970U using Tapatalk
Old 31st May 2020
Sparkes's Avatar
Default Drag pipes
Hi,
Thanks for your replies...
Much appreciated... I should’ve mentioned that UK would be easier re postage.
All the best
Neil
Old 31st May 2020
Highly-Dangerous's Avatar
SPANIARD
Glass of water and tin-foil.... make a ball with the tin-foil, soak it with water and start, gently.. not too much pressure, rubbing the chrome.... MAGIC!!!
