0 Hello From Cayman Islands
Last Post: Veeflys
0 Introduction
Last Post: Veeflys
Last Post: Holytown
Last Post: Four Speed
Last Post: skypeace
0 Replacing Stock Sealed Beam Headlight in my 1991
0 Newest "MYSTERY" problem - No life to my ride!
Last Post: farmall
5 Summer time heat
Last Post: Scott
10 What's your Personal Tech
Last Post: Kbetts
0 Do you like Brazilians???
Last Post: oupa
Last Post: 2cvandy
0 Mid or forward controls.
0 Should I buy a Sportster??
0 Clutch won't disengage
Last Post: 72 Ironhead XLH
0 LED turn signals problem?
0 compression problems
0 Who's still riding???
0 Air Filter Soaks With Gas
Last Post: 93sportsXLH
Last Post: 83XLX
Last Post: Eddie Lives On
0 Vote for your favorite Babe Jump Babe.....
0 1981 ironhead xlh PROJECT
Last Post: owlsplace
0 Forks and Triple Tree and wheels?
Last Post: CaymanHarley
0 VOES Switch on CV carb conversion.
0 A Day in the Life...
0 900 dual carb front head
Old 7th January 2019
Beelzeboss's Avatar
Beelzeboss Beelzeboss is offline
Beelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant futureBeelzeboss has a brilliant future
Default Cometic gasket set part # ?
Hi all,
I've been looking at a top end gasket set for my Sporty since I've currently got a leak from the front base gasket and front lower pushrod seal, but I can't find the correct part number on the Cometic site.
The bike is a 1996 XL1200S and I may do cams at the same time, so actually the part number for the full kit wouldn't go amiss either.
This is the search I've run on their website:
https://www.cometic.com/search.html?...ster+kit+3.500
Sporty kits with the 3.5" bore (1200), but none of the kits are narrowed down by year of manufacture so I can't really tell what's for an ironhead, rigid or rubber mount...
Any help would be appreciated as I'd like to order the gaskets ASAP.
Cheers,
Andrew
iNSaNeSHaNe's Avatar
iNSaNeSHaNe iNSaNeSHaNe is online now
Sportster/Buell Year: 1985
Any of those kits should work for you as they are all evo kits and have pretty much the same gaskets.
I have gotten several sets for the ironhead and they specify for the ironhead and the ones I have gotten for the Evo cover several years and so far have all been the same set.
Old 16th January 2019
T_worth T_worth is offline
Sportster/Buell Model: Xlh 1200
Sportster/Buell Year: 96
T_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura aboutT_worth has a spectacular aura about
I've used the ETS top end rebuild kit. I've also had to order extra gaskets and had similar questions because I have S&S adjustable pushrod covers. If you call cometic, they'll be able to track down the proper part that you need
Adam76 Adam76 is offline
Sportster/Buell Model: 48 special
Sportster/Buell Year: 2018
Adam76 is a splendid one to beholdAdam76 is a splendid one to beholdAdam76 is a splendid one to beholdAdam76 is a splendid one to beholdAdam76 is a splendid one to beholdAdam76 is a splendid one to beholdAdam76 is a splendid one to beholdAdam76 is a splendid one to beholdAdam76 is a splendid one to beholdAdam76 is a splendid one to beholdAdam76 is a splendid one to behold
Cam anyone help me with a link or a place I can get 030 HG and 010 / 020 base gaskets for a late model sporty 1200?
Thanks
rocketmangb's Avatar
I think those gaskets are made by Cometic
Check with Hammer Perf.
https://www.1250kits.com/xlgaskets.shtml
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
https://www.cometic.com/c-1280258-au...d-gaskets.html
You can also call cometic and they can assist ya
Thanks, HAMMER is supplying me a set.
Sent from my SM-T355Y using Tapatalk
