Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Top End
0 Hello from Tennessee
Last Post: jharback
0 Poll: How Tall are You?
Last Post: geekonabike
0 Mustang's new seat? Anyone tried it?
Last Post: Adam76
0 Ride Height Change With Shock Length Change
Last Post: Adam76
6 Aerostich Suit on a Sportster??
Last Post: BWB75
Last Post: Bone
0 Riser Fitment Question
0 primary chain adjuster spring load..?
Last Post: 83ironman
0 changing rocker arm bushings
0 Realistic performance guesstimate?
Last Post: Curbside
Last Post: Adam76
0 joyride memories xlx ironhead
0 ******* usps
Last Post: oupa
0 A Weekend at the Races
Last Post: oupa
0 My new buckhorn bars
Last Post: oupa
0 timing troubles!
0 Is this 1200R worth $4500?
Last Post: Bone
Last Post: 1977iron
0 WTB: S&S Super E Jets
Last Post: wrkdWS6
4 Grinding noise when revving up
Last Post: Grumpy-Biker
0 Winter Storm Warning
0 Mid or forward controls.
Last Post: 5mel42
jurneyman (77), AdO650 (63), xlsport (61), darth (58), mcsmokinp (54), stalkie (54), unleashed66 (53), 66xlch (53), lownslow (47), hrg (45)
Old 30th November 2017
jordan1200's Avatar
Default Buell M2 head and piston/cylinder specs
Hi I am wondering if anyone has a copy of the Buell Thunderstorm heads and 15° dome piston specifications chart for tolerance's and service wear limits for the M2 Buell.
I have the 1999 sportster FSM but not sure how the specs compare from the 1200 sportster to the 1200 Buell M2 (Thunderstorm) top end.
Jordan1200
SE XL bolt-in cams .497's
Dynatek 2000i Ignition
SE 1340 air cleaner
