0 Winter Storm Warning
0 Is this 1200R worth $4500?
4 The no-debate OIL POLL
Last Post: bplinson
0 Celebrating Sportsterpedia's Third Anniversary
0 68 xlch wiring
Last Post: Zach68
0 joyride memories xlx ironhead
0 Does Synthetic Engine Oil cause Higher or Lower temps at the oil tank?
Last Post: Sportycus
0 Mustang's new seat? Anyone tried it?
0 timing troubles!
Last Post: The Doctor71
0 Photos: King Peanut or Regular Peanut tank?
Last Post: Calcustom
0 XL883L 2006 coughing and backfiring
Last Post: Bama Lee XLC
0 How many helmets?
0 Clutch Spring plate poll
Last Post: bimbo
0 What oil temp do you run
Last Post: JKKO
Last Post: 1977iron
0 Who's still riding???
Last Post: 1977iron
0 Bushing alignment
0 Helmet poll
0 Pull cam cover for powder coating
Last Post: spoon
5 Jiffy Standing
Last Post: rurlndum
steve yorke (61), edman (53), Hudsonator (51), kozman32 (51), R3DN3X (49), gmcsid (48), mitch (43), Gotenfan (29)
Old 5th June 2009
Oldwrench Oldwrench is offline
Sportster/Buell Model: Sportsters
Oldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the roughOldwrench is a jewel in the rough
Default Rear Brake Pads
I don't use the rear brake much, so I still have plenty of material remaining with over 30,000 miles on the original pads.
On the earlier Sportsters, the rear caliper DOES need to be removed first to replace the pads. It is sometimes hard to actually see the pad thickness with the caliper in place, especially the inner pad. It doesn't hurt anything to pull the caliper to get a good look. There is no trick to simply putting the caliper back in place as long as no one touches the brake pedal while it is off.
Old 5th June 2009
argentcorvid argentcorvid is offline
Sportster/Buell Model: XL1200
Sportster/Buell Model #2: XB12XT (Ulysses Touring)
argentcorvid will become famous soon enoughargentcorvid will become famous soon enoughargentcorvid will become famous soon enoughargentcorvid will become famous soon enoughargentcorvid will become famous soon enoughargentcorvid will become famous soon enough
Originally Posted by xena View Post
It's not necessary to remove the caliper to inspect or replace the pads.
Replaced mine last summer following the service manual. Was fairly
simple imo and I had never done them before.
how did you do that without taking the caliper off the frame? Is this a newer model thing?
mine's a 1998, and unless you take the wheel off, there's no way to get at the pads. the manual says to do it that way, and I assumed that it would be similar enough.
Mods:Forcewinder XR, V&H Straightshots (wrapped), Keihin CV40 w/45 Pilot, 170 Main, N65C w/1 shim, SE ignition module, Front turn signals on the forks, Rear signals on license plate bracket, Drag bars w/~4" pullback risers, Xena's Speedometer mounting mod (Thread #3883), Mustang Seat, Removable windshield, Forward controls, Road King Rear shocks
Old 5th June 2009
xena's Avatar
xena xena is offline
Assistant Administrator
Argent if I'm wrong I stand corrected. I didn't think an 01
sporty would be that much different but it sounds like it may be.
The rubbermounts are simple to replace the pads, just remove
the pad pin and they pop right out both front and rear.
Don't think it was more than 10 minutes to replace both sets.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams
Python 3 Slip ons
TC88A running Xena's Black Panther Map
My 1212 Conversion Thread
XL Forum Members Map
Old 5th June 2009
no need to apologize, obviously they changed the design somewhere in there. I'm not sure when they changed it (2003, like everything else?).
So what you're saying is that it went from pretty easy, to really, really easy?
Old 5th June 2009
xlcruser's Avatar
xlcruser xlcruser is offline
xlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the roughxlcruser is a jewel in the rough
Originally Posted by Oldwrench View Post
I can't quite bring myself to let the pads wear down to the 1/16" the book allows. Logic says it's okay. The little hairs on the back of my neck say otherwise. When they get much under 1/8th inch I replace them.
I've got to agree with you on that.
Old 5th June 2009
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
Maybe "ignorant is bliss"..as I have over 20K on mine.....and they still stop great........and aren't making any noise. I've looked at them and I still have pads!
PS: I ride real hard too!
Maybe I better go look again
EDIT: just looked....fronts in great shape........and I use them HARD........rears.......not so good!
Now I'm going to need to replace them!
Now here's another question: Chicago Harley 42836-04 $47.96 42836-04 A $32.76 ?
Anyone know the difference?
Stuff: YES
Old 5th June 2009
brprider's Avatar
brprider brprider is offline
Sportster/Buell Model: Orange 1200R
brprider will become famous soon enoughbrprider will become famous soon enoughbrprider will become famous soon enoughbrprider will become famous soon enoughbrprider will become famous soon enoughbrprider will become famous soon enoughbrprider will become famous soon enough
Anytime you see a part number with an A or B behind it, it's been upgraded. Hopefully for the better. Maybe the original pad material wore down too quickly, etc... Why it's cheaper, who knows, but I wouldn't complain.
Between you and me, for that kind of money, I would buy aftermarket pads. I like EBC. Lots of others to choose from also.
Everyday looks like a great day to play hooky.
I believe I'll start today...
Old 5th June 2009
BWP 5p's Avatar
Just orderd a pair of Lyndall pads!
Old 5th June 2009
rdgzoe's Avatar
rdgzoe rdgzoe is offline
Sportster/Buell Model: 883/1200 Sportster Low
Other Motorcycle Model: DYNA Street Bob
Other Motorcycle Year: 2007
rdgzoe is on a distinguished roadrdgzoe is on a distinguished roadrdgzoe is on a distinguished roadrdgzoe is on a distinguished roadrdgzoe is on a distinguished road
I would replace them quick. It would a big pain to replace the rotors because of worn bake pads.
Old 5th June 2009
brprider's Avatar
I keep hearing good things about Lyndall pads. I think I'm going to try those next.
