0 1200 kit coversion with 50k miles?
Last Post: hexnut
0 Help to ID 1974 Sportster XLCH custom parts
Last Post: spacecoast
0 Hello from Germany
Last Post: Clementine
Last Post: Sprtstr1200s
0 Cometic gasket set part # ?
Last Post: Adam76
0 THE Trainspotting Thread
0 Service interval on all rubber brake components
0 Hard to shift
Last Post: rog
Last Post: 11B40
0 The Armor Jacket Poll
0 What's your helmet?
Last Post: Nayra
0 How many helmets?
Last Post: Bama Lee XLC
Last Post: Nayra
Last Post: Lone Rider
0 Sportster Street Tracker GSXR Fork Swap!
Last Post: Greg_Wayne
0 Tranny Question
Last Post: sltm1
0 Who's still riding???
0 Is this 1200R worth $4500?
0 WTB: Factory Ironhead 2-1 Head Pipes
Last Post: wrkdWS6
  #131
Old 26th July 2015
chadthe's Avatar
chadthe chadthe is offline
chadthe is an unknown quantity at this point
So besides these lithium batteries people are changing to, what other batteries are being used besides the stock HD one? Specifically smaller sized batteries that I will not need a special charger for and will not set me back $180 or more.
Old 27th July 2015
oscardog1 oscardog1 is offline
Other Motorcycle Model: Yamaha xj 600 diversion
Other Motorcycle Year: 1997
oscardog1 is an unknown quantity at this point
I used a Yuasa YTZ14S, Dont know how much in the States, but in the UK it was £60.
Old 27th July 2015
TheEssence's Avatar
TheEssence TheEssence is offline
TheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to allTheEssence is a name known to all
I got my Li battery on amazon for $104.....
"Ah! dear friend, you little know the possibilities which are in you."
Old 29th November 2016
Almond farmer's Avatar
Almond farmer Almond farmer is offline
Sportster/Buell Model: 883C
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1980
Almond farmer has much to be proud ofAlmond farmer has much to be proud ofAlmond farmer has much to be proud ofAlmond farmer has much to be proud ofAlmond farmer has much to be proud ofAlmond farmer has much to be proud ofAlmond farmer has much to be proud ofAlmond farmer has much to be proud ofAlmond farmer has much to be proud ofAlmond farmer has much to be proud ofAlmond farmer has much to be proud of
I know this thread is seven years old, but there is new technology with the advent of
lithium ion type batteries made for snow mobiles, ATVs, & motor cycles.
Much smaller and much less weight than lead acid type battteries used in 2007-2009.
For example the lithium ion battery by Deltran, brand name, Battery Tender, p\n BLT14A240C
has dimensions, length=5.27", height=3.62", width=2.55" compared to the stock H-D,
Length=5-7/8",height=5-3/4", width=3-7/16".
Replacing the lead acid or even a new generation AGM type battery of equal size to the older lead acid type battery with lithium ion battery increases the available volume in the battery tray area for the ECM.
Thus, leaving the selection wide open for stationary cushion type seats without the unsightly tail seat section.
If the ECM is strapped to the outboard side of the battery , the lithium ion battery allows an additional 3/4" clearance to the battery cover.
The thickness of the ECM is 1-1/8", width=4", length=6-1/2" including connector.
With these dimensions, could find the ECM location combination that fits into the tray volume.
Surely, there are many combinations that fit and not only one unique solution.
Old 3rd December 2016
WKNDZ's Avatar
WKNDZ WKNDZ is offline
Sportster/Buell Model: XL883N
Other Motorcycle Model: Softail Slim
WKNDZ has much to be proud ofWKNDZ has much to be proud ofWKNDZ has much to be proud ofWKNDZ has much to be proud ofWKNDZ has much to be proud ofWKNDZ has much to be proud ofWKNDZ has much to be proud ofWKNDZ has much to be proud ofWKNDZ has much to be proud ofWKNDZ has much to be proud ofWKNDZ has much to be proud of
Yep! FWIW I'm using an EarthX ETX-36C so I can move the ECM
(and wiring) from in-front-of the frame down-bar to inside the
battery tray (while its down for the 1250 conversion)
Old 18th December 2018
Sportster/Buell Year: '59
Other Motorcycle Model: 2004 XL883 '57 Tribute
PetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud ofPetesPonies has much to be proud of
So with an '06 . . . and not changing the battery, what is the easiest relocation for the sole purpose of gaining a tiny bit more space for a different seat?
Pete's Ponies Mustang RUSToration & Performance
Folkie Folkie is online now
On an ‘06, the ICM is under the front of the seat; why would you want to move it at all?
Sportster/Buell Year #2: 2008
Default Location
The stock seat is good but the optional Sundowner is more comfy.
Sundowner has no provision for the ICM
I think it is closer to the center of the seat, to me it is bigger than the Princess and the Pea, right under the old hem-a-roids.
Depends which Sundowner you're looking at. # 51507-04 and 51509-04 are made for the '04 - '06 bikes, and certainly have provision for the ICM.
Folkie . I answered that ?? I said for some seat clearance. My seat I want to use hits the ICM slightly. If it was 1/2" lower, I'd have no issue.
