0 New member from Santa Clarita, CA
0 Hello from Waipu, New Zealand
0 Old Parts
Last Post: Yakcm2
Last Post: davixlrtt
0 magnetos 101 questions
Last Post: hawgford
0 mainshaft oil leak
Last Post: T_worth
0 ***DK Custom-LIMITED TIME Sweetheart Deals-Save 10% On Select Products***
0 Bratstyle Japanese Influence Bike Photos
0 In PA Or Nearby
Last Post: Wilkinson949
Last Post: Darkseacret
Last Post: lucky23
Last Post: ReddTigger
Last Post: SLW210
Last Post: SLW210
0 A thunderstorm -weather that is
0 What oil temp do you run
Last Post: oupa
0 Frontbrake upgrade - simple and cheap - how to will follow if there's any interest
Last Post: Yakcm2
0 stock modded exhaust vs short shot
Last Post: Bruce
efi, efi sportster, fuel line, fuel tank
  #31
Old 30th June 2013
wachuko's Avatar
wachuko wachuko is offline
Sportster/Buell Model: Forty-Eight
Other Motorcycle Model: CVO RK
Other Motorcycle Year: 2014
wachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond repute
Dan,
Just want to add myself to those that are thankful for this video. Clear, complete, and easy to follow. Excellent! Thank you!
Now on to tackle replacing the covers in my 48.
'16 H-D Softail Slim S/'16 Triumph ThruxtonR (Gone: '14 HD RK CVO / '13 HD Forty-Eight)
Old 27th July 2013
rdunnill rdunnill is offline
Sportster/Buell Model: XL883L
Sportster/Buell Year: 2014
Other Motorcycle Model: Super Glide Custom
rdunnill is an unknown quantity at this point
Originally Posted by Screw Loose Dan View Post
Thanks guys. I know it's not the most riveting thing to watch, but if it helps a couple people I guess it's good enough.
I liked it -- I'm planning on converting my Nightster to a 4.5-gallon tank and this is most helpful.
Well done!
Old 20th December 2013
20131200c 20131200c is offline
Sportster/Buell Model: sortster 1200custom
20131200c is a glorious beacon of light20131200c is a glorious beacon of light20131200c is a glorious beacon of light20131200c is a glorious beacon of light20131200c is a glorious beacon of light20131200c is a glorious beacon of light20131200c is a glorious beacon of light20131200c is a glorious beacon of light20131200c is a glorious beacon of light20131200c is a glorious beacon of light20131200c is a glorious beacon of light
Thanks for posting this it was very very helpful in the removal of my 1200c tank, much clearer thank if i had used just the shop manual. Are there anymore covering other maintenance jobs. Thanks again
Old 19th March 2014
sewercity712 sewercity712 is offline
Sportster/Buell Model: sportster48
sewercity712 will become famous soon enoughsewercity712 will become famous soon enoughsewercity712 will become famous soon enoughsewercity712 will become famous soon enoughsewercity712 will become famous soon enoughsewercity712 will become famous soon enough
This video is a great help to me, much appreciated, puttin apes on my 2010 sportster 48 this weekend, and its going to be alot easier now i watched this, saved me alot of bs
Old 25th July 2014
splattttttt's Avatar
splattttttt splattttttt is offline
Sportster/Buell Model: SEVENTY TWO
Sportster/Buell Model #2: Seventy Two
Sportster/Buell Year #2: 2014
splattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to allsplattttttt is a name known to all
Originally Posted by motorend View Post
Wow, I never thought of using the battery cover for a tool tray.
Dan's a "G"!
Old 3rd March 2015
beardedsk8er's Avatar
beardedsk8er beardedsk8er is offline
Sportster/Buell Model: Sportster Custom 1200
beardedsk8er will become famous soon enoughbeardedsk8er will become famous soon enoughbeardedsk8er will become famous soon enoughbeardedsk8er will become famous soon enoughbeardedsk8er will become famous soon enoughbeardedsk8er will become famous soon enoughbeardedsk8er will become famous soon enough
Originally Posted by Bigeeboo View Post
IMPORTANT!! - The Factory Service Manual is very clear about this! Gasoline can kill you. It is dangerous and explosive. After reading the manual, I'm pretty sure most people that do this will die. Please read your FSM for further important information.
most ppl that take the tank off will die? Im confused
thanks for the vids!
Kinda reminds me of the first time I swapped tanks on mine. Total disaster... Before I started the removal process, I had loosened the gas cap to check how much fuel was in it and for some reason, never fully tightened the cap back on. So after I un-did all the bolts and flipped the tank over into my lap, I had fuel gushing out into my lap. I was like, WTF!!!, not remembering the cap was loose and thinking there must be some other reason fuel was gushing out, like a breather hole in the cap or something. Anyway, while still spilling fuel everywhere I grabbed an available bucket and balanced the tank over the bucket while removing the fuel pump screws. And just let the fuel drain into the bucket while installing the new tank. Installed the new tank and only when taking off the fuel cap from the old tank to put on the new one, did I realize it wasnt even tight. Anyway, I was totally soaked in fuel during the whole installation process and I didn't die..
Old 3rd March 2015
scooby scooby is offline
Sportster/Buell Model #2: FXLR
Sportster/Buell Year #2: 1988
scooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant futurescooby has a brilliant future
Great vid!
Nice bike you have there, didn't know that color and graphics existed in 2007.
Hey someone mentioned a vid of rear tire removal? I didn't see that if true.
I am about to embark on a tire change and looking for methods of a hollow axle alignment, don't know if the 07 has this or not.
Keep up the good work!
Old 3rd March 2015
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
Originally Posted by scooby View Post
Great vid!
Thanks! Mine's a one of a kind that way. See my (old) thread on the changes here.
I'm sure one exists but I'm not a familiar with any videos of rear tire changing. My 2007s have solid axles, so I have limited experience with the hollow axles (although my 2012 XR does have them). Perhaps someone else can point you in the right direction.
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 8th October 2017
009jim 009jim is offline
009jim is an unknown quantity at this point
Excellent video.
Old 26th October 2017
i82much i82much is offline
Sportster/Buell Model: XL 1200 c
i82much is a splendid one to beholdi82much is a splendid one to beholdi82much is a splendid one to beholdi82much is a splendid one to beholdi82much is a splendid one to beholdi82much is a splendid one to beholdi82much is a splendid one to beholdi82much is a splendid one to beholdi82much is a splendid one to beholdi82much is a splendid one to beholdi82much is a splendid one to behold
I know this post is dated but damn was it good!
Thanks for the nice tutorial!!
