Last Post: Nayra
0 Help me with the physics of the Bendix float
0 Hello from Seattle
Last Post: Nayra
0 Hello from San Clemente, California USA
Last Post: oreocat1
5 What's Your Temp Today
Last Post: Nayra
14 Saying Hello /shwmae
Last Post: oreocat1
0 Hello from NY
Last Post: oreocat1
6 Is Your SPORTSTER...
Last Post: jharback
0 F/S: HD Solo Seat and Pillion '86-'03 $100 OBO
0 Front brake lever
0 A Separate Speedo and Tach
Last Post: Woody9225
Last Post: oupa
Last Post: Blackbenny
0 Shotgun Porn
Last Post: Bama Lee XLC
0 Late Ironhead cases interchangeability
0 stress killer
0 A thank you
0 Side stand issues on can bus Sportsters?
0 12" or 14"? (Apehangers)
Last Post: Nrg2brn
0 It's Flame__'s Birthday!
0 Excited to join the sportster family!
0 Forum problems???
cobra0478 (75), Han (62), priell3 (58), Byrdman (54), jsta (52), YaeDio (51), doc (45), jfunk (45), lenainrouge (44), JohnDao (40), Razer883 (33), Slapchop68 (25)
  #91
Old 4th August 2015
wachuko's Avatar
wachuko wachuko is offline
Sportster/Buell Model: Forty-Eight
Other Motorcycle Model: CVO RK
Other Motorcycle Year: 2014
wachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond reputewachuko has a reputation beyond repute
Just to double check I took a few additional measurements... and the caliper mount needs to be cut 1/4" (6.35 mm). No surprises there as the spacer on that side was indeed reduced by 1/4" but I just wanted to double check.
'16 H-D Softail Slim S/'16 Triumph ThruxtonR (Gone: '14 HD RK CVO / '13 HD Forty-Eight)
Old 24th August 2015
wachuko's Avatar
Modifying the caliper...
Done! New seals for the brake line, bolts where left alone as they do not interfere with the rotor. Plus you can't see them anyway... (I might get new ones and modify them anyway, just so that I know those were adjusted to size )
Not enough time for a test ride...family is calling for attention.
Old 25th August 2015
wachuko's Avatar
Done! Took her out to fill her with gas (since I switched the tanks when the gas was almost gone...). Rides great!
Can't believe that I am finally done with all mods on this bike...
Old 26th August 2015
wachuko's Avatar
Just finished putting 137 miles on the bike testing everything. Hard braking, small pot holes or imperfections in the road, swerving, etc... stopped a few times to make sure nothing was rubbing or anything was out of the norm... nope... all is perfect.
Everything felt great!!
The combination of a wider rear tire with the different tire brand all around, just feels great!!
Only thing I forgot to mention... I shaved an additional 1 mm from the head of each bolt that go on the right side (the side with no caliper). These are the bolts that hold that thin hub cover... Did it just to get that additional clearance from the fork...just to feel better...
Old 1st June 2018
Wedgey Wedgey is offline
Sportster/Buell Model: XL1220X
Sportster/Buell Year: 2012
Wedgey will become famous soon enoughWedgey will become famous soon enoughWedgey will become famous soon enoughWedgey will become famous soon enoughWedgey will become famous soon enoughWedgey will become famous soon enough
Originally Posted by Cropduster View Post
Fat Bob wheels purchased, along with ABS bearings, spacers, valve stems, oh and a reinforced swingarm will be going in with them as well....
More money LOL!!!
Double post, dunno why,
Oh well, they should look SAWEEET!
What size rims/tires did you go with?
I never get sick of looking at mine
Old 1st June 2018
jammantoo's Avatar
jammantoo jammantoo is offline
foot in mouth member
Sportster/Buell Model: 48
Sportster/Buell Year: 2016
Other Motorcycle Model: Dou-glide
Other Motorcycle Year: 63
jammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond reputejammantoo has a reputation beyond repute
Looking mean, great build
Join the PEANUT CLUB, it gives you an excuse to stop and smell the roses
Old 19th June 2018
You may find that the belt rubs on the tire when pushing backwards for more than a few meters. Mine rubs slightly but rights itself when pushed forward.
How did you approach the licence plate mount? I ended up going with a lay back frame mounted on the top of the guard. The plastic hardware for the Australian version wouldn't fit with the 180 and my side mount also had issues but I wanted to ditch it anyway.
You'll be getting the itch to go with a set of triples off the FatBob as well and go twin disc setup?
Old 19th June 2018
That's good to know thanks, the license plate mount is far enough back that it doesn't touch the tyre, mine isn't really low, i have the 49mm forks and the fatbob lowers are longer than the sporty ones so i'm stuck with just one front brake, but it's a PM 4 pot, and i like the handling that i have.
How close is the upper belt guard to the tyre on yours?
I can't remember how close the upper is, I'll have to look when I get home.
I ended up with aftermarket triples in wide glide with a +3 deg rake (Hawg Halter brand), fork legs, and guard off a FatBob (2012 had the thinner tubes) with a pair of 6 pot PM calipers and rear disc from a 2014? Breakout.
