0 Hello from the Netherlands!
0 Khk flywheels in my ironhead....timing
Last Post: vonhatch
0 Cv carb jet question
Last Post: Bob F
0 Harbour Freight jack
Last Post: Bob F
0 Safety Announcement; Re: Saint Patrick
0 900 dual carb front head
0 Gotta Start a Thread for the Streetfighter Too!
Last Post: Bryan83taco
0 Replacing Stock Sealed Beam Headlight in my 1991
0 Air Filter Soaks With Gas
Last Post: 83XLX
0 Replace crank bearings
Last Post: Maxdog2
Last Post: Four Speed
0 Tacho Ratio's
0 VOES Switch on CV carb conversion.
Last Post: BlackAce
0 HD 100th Anniversary Sporty Pic Thread
Last Post: MoneyFor
0 LED turn signals problem?
Last Post: Scuba10jdl
0 Lets see your Forty Eight's
Last Post: TonyGall
0 XB12 Heads on Wiseco Big Bore Kit
Last Post: sschratt
Last Post: 83XLX
0 1980 Sputhe Sportster
Last Post: chevelle
0 Mikuni HS40 flatslide
0 A Day in the Life...
drifter44 (75), Streak70 (71), Rayzer (61), ridefree1 (57), erk (53), LOBO (51), motley79 (40), polaris0352 (38), TManos916 (38)
Old 18th July 2016
oldsoldier oldsoldier is offline
Sportster/Buell Model: xl1200r roadster
oldsoldier is a splendid one to beholdoldsoldier is a splendid one to beholdoldsoldier is a splendid one to beholdoldsoldier is a splendid one to beholdoldsoldier is a splendid one to beholdoldsoldier is a splendid one to beholdoldsoldier is a splendid one to beholdoldsoldier is a splendid one to beholdoldsoldier is a splendid one to beholdoldsoldier is a splendid one to beholdoldsoldier is a splendid one to behold
I actually got the battery cover clips yesterday. I havent been off of work long enough to go swap them out, so I dont know what the difference between them is. I do know that, when I went to order them, using the part # in the above link. The part was changed from an A to a C, as it was the latest part #. The actual changes in the part though, I dont know. Nor do I know that they fit yet. SHOULD find out tomorrow.
Old 29th June 2018
tamaro tamaro is offline
Sportster/Buell Model: 883
tamaro is an unknown quantity at this point
Ronnies Hd does have the clips, thanks! The dealership will as well, or they can order some for you.
However, on my 2006 Sportster 883, the new dual-clip style creates a space between the cover and the frame. I’m concerned water will seep into the fuse box/battery. Any fixes/suggestions for a more flush fit?
Not sure how to post a photo yet from my mobile
Old 29th June 2018
ParrotHead's Avatar
I am the great Cornholio!
Other Motorcycle Year: 1974
I've had the clips for several years and probably 40-50,000 miles with no issues. It wasn't water proof to begin with.
John Wayne - "The Shootist"
Click here to listen to my interview on the Motorcycle Men Podcast
