Last Post: oupa
0 Runs rough on highway.
0 I'm going nuts
Last Post: Another.Mike
0 Tried starting the bike this morning, batter charged, but bike wont turnover?
Last Post: atVMAX99
0 Iron brake light help
Last Post: Bryan83taco
0 Spectro STL 75W140
Last Post: Four Speed
0 Lacing a 21 inch wheel to a 19 inch hub
Last Post: Mad Max
0 Modified heads
0 79 Tranny
0 1200S cam comparisons
Last Post: Saint666
0 Valve adjustment question
5 Summer time heat
0 Drag Specialties Headlight Housing + LED?
Last Post: Eddie Lives On
0 Front cylinder noise
0 How do you upshift?
0 WTF Happened
Last Post: VaFish
Wild One, Bugs (66), Blazer (63), OnDVirg (63), Buggyboy (60), TheChimp (45)
Old 27th March 2018
201648Rider 201648Rider is offline
Sportster/Buell Model: 48
Sportster/Buell Year: 2016
201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future
Default 2016 48 Hesitating
I'm getting some odd behavior thats getting increasingly worse.
When not under acceleration I'm getting some hesitating and a bit of popping almost like a light backfire. Its getting a bit unsafe around corners as ones the hesitation stops it comes back to life.
Its happening almost all time most noticably at low rpms just maintaining speed. It smooths out once I add a bit of throttle.
I've got a thousand miles or so on my 1275 kit with dynotune and I'm not getting any error codes.
I plan on pulling the plugs tonight. Any other tips on diagnosing? I've ran through about 3 tanks and tried some different fuel stations but all seem the same.
I've also been data logging alot but I've never done anything with my logs. I guess its time to start getting familiar with the software side of things.
Old 27th March 2018
BKB's Avatar
BKB BKB is online now
Check for intake leaks.
Brian '09 1200C (black of course), 19" front wheel, det. windshield, Sundowner, mini apes, Big Sucker, x14IEDs, 12.5" Progressive 412's, Intiminators, Gronk mod
Old 21st April 2018
Pulled things apart last week and dropped some plugs in. Big improvement initially but its slowly coming back. At very very light throttle its like its stumbling then the power snaps on if you juice it a bit. Put the dynojet on and noticed its usually around 10% throttle when not under load.
Any other tricks to troubleshooting without any error codes?
Old 22nd April 2018
andy_t's Avatar
andy_t andy_t is offline
andy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant futureandy_t has a brilliant future
did you check for intake and exhaust leaks? If not you should start there.
Andy
Old 22nd April 2018
XLXR's Avatar
XLXR XLXR is offline
this is very common when idle jet, air mixture screw and idle speed settings are not correct. These settings must then transition to needle and needle jet as you open the throttle to mid range. Set the air mixture screw and 2 1/2 turns outs, idle at 950 rpm. Do the plug chop method to check plugs at idle and mid throttle. If they are not close to perfect, change idle jet or needle. If they are close, then work with idle mixture screw to find the setting that stops the hesitation. I wrote a sticky on this 10 years ago. There are other good carb tuning threads in the sticky section.
Old 25th April 2018
Andy_t I pulled the intake ff and reseated everything, checked all wiring and reinstalled the aircleaner and put new plugs in. Things seemed smoother for a few days but im now back where I started. I need to get an adapter for my compression tester to rule out a leaky head gasket.
Whats the best way to track down an intake leak?
Xlxr fortunately/unfortunately im on efi so no carb tuning on my end
Old 25th April 2018
Sportster/Buell Model: XLH883
hammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant futurehammer6315 has a brilliant future
I had a similar problem on my 2012. I believe it is caused by a lean mixture. The motor company builds these to be compliant with epa regulations, never mind if the result is poor performance. The fact that you have had motor work done may be contributing to your symptons. If you can find a competent tuner, they may be able to help. In my case, I tried three different cures, and was about to unload my bike before I got it cured. Good luck with yours.
Old 25th April 2018
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
What tune are you running? Is this a Hammer 1275 kit with a Hammer tune? Is this with a PowerVision tuner? Have you done any autotuning? You don't have an autotune map loaded by accident?
I agree with others to check for an intake leak. You mention taking the "intake ff " and reseating everything, I'm not sure what "intake ff" means. The intake leaks that present issues are typically between the intake and the engine intake port. Personally I have found intake/sensor cleaner sprayed around the head ports/intake seals will show a drastic change in idle if there is an intake leak.
Ensure the tune you are using has the correct gearing and speedo adjustments (compare current map to the original stock tune, presuming you haven't made any changes to the gearing). If the ECM/tune has the incorrect gearing values, it can impact idle while moving.
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 25th April 2018
Screw Loose Dan thanks for the advice,
Confirming its a 1275 kit with 560cams, exhaust, and intake. With the tune being provided by hammer for that configuration. I've put about a thousand miles since the upgrades with no issues and only started having the hesitation recently.
I haven't intentionally changed anything with the tune since then, but I'll try re-installing the map they sent just to be sure.
Apologies for the type-o (was on mobile) I pulled the intake and air-cleaner assembly off, meaning the entire throttle body and intake runners off the jugs and reinstalled. I had not tried the intake/sensor cleaner trick but I should try that next. I should also note that I think the hesitation went away for a day or so (at least it improved) so perhaps the intake is just not seating properly.
hammer6315,
Thanks for the tip. I still plan on a proper dyno tune once I locate an experienced reputable tuner in my area, hopefully I can get this issue sorted prior to that.
Old 26th April 2018
Did you reassemble with the original intake seals? They are rubber and in theory should seal multiple times without issue. However, many of us consider them a regular maintenance item. It's also generally recommended to use a lube/grease on the seals during reassembly.
I'm not trying to indicate that an intake leak is definitely your issue, but they are generally easy enough to eliminate, it's a good place to start.
FYI - I found the intake cleaner worked well for finding an intake leak when cleaning the intake on a running bike and realizing it made the bike quit running immediately upon spraying it in the intake. When sprayed around the leaking intake seal, the bike quit running immediately, just as if I had sprayed it in the intake.
