0 Flat Tire
0 Rubbermount shocks on a rigid mount?
0 Finding a new doctor...
0 1968 xlch
Last Post: denguy
0 Motorcycle Events
Last Post: rhartlin
0 Bendix / Zenith questions
Last Post: hawgford
5 What's Your Temp Today
Last Post: Kbetts
0 C&C Seat Decision
0 1200 kit coversion with 50k miles?
Last Post: Blue Scoot
0 Stock Straight Rate Fork Spring Weight on Rubbermount 1200C
0 Arbor press for crankshaft
0 So heres the plan
Last Post: Bryan1976
0 compression problems
Last Post: oupa
0 Dyno Run, V&H straight shots vs. Screamin' Eagles
0 Forum problems???
Last Post: bplinson
Last Post: moparnut72
10 What's your Personal Tech
0 ultima iggy,, static time vs dynamic time
0 Seized Oil Pump
0 Hello from Seattle
Last Post: racemoto
0 my build in my apartment
0 Rocker Lockers - Quiet Down Annoying Top End Ticking
Old 26th April 2018
XLXR's Avatar
XLXR XLXR is offline
OOpps, I thought it was a 2006 bike. Check the stepper motor (I think your bike has one) and enrichment table. Just a guess because I don't know much about EFI. Call Hammer.
Old 27th April 2018
201648Rider 201648Rider is offline
Sportster/Buell Model: 48
Sportster/Buell Year: 2016
201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future
Still waiting on a compression tester adapter but it looks like I have indeed failed a head gasket on the front cylinder;
https://photos.app.goo.gl/mSvTuYaetD1DAZyc9
Old 27th April 2018
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
Yeah, that doesn't look good. Hopefully that's it. Kinda a pain to have to take it all apart again, but should be relatively easy to address.
I presume you used the Cometic gaskets that Hammer normally recommends/supplies?
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 30th April 2018
Correct I used the Hammer .30 x 3.625. I just ordered another complete kit. Doesn't hurt to have spares I guess, and I still have the factory motor to re-assemble.
I think my lack of patience warming the bike up before riding is likely what caused the fault. I try to be quick about it in the am so I don't wake the neighbors and usually similarly when leaving work.
Any ideas what temps I should be trying to keep the bike under? I have also been hitting a lot of stop/go traffic due to construction on my commute and wonder what the "shut-off" point should be when things climb to high.
Old 30th April 2018
I doubt you blew a head gasket because you weren't warming the bike up. My (limited) experience has been head gaskets fail because poor assembly technique or a much bigger issue internally to the engine. Anything is possible I guess, but I would be surprised not warming the bike caused an issue (presuming you weren't going full throttle on a cold engine). You might find loose head bolts when you tear it down.
I've never gotten a good answer to what the highest engine temperature should be. And, to be clear - we are talking about Engine Temperature (ET) as reported by the ECM, NOT oil temperature. I usually don't fret until I get ET's over 400°F. The majority of the time I'll see ~380°F fully warmed up. I pay close attention when I'm in the low 400's, but I don't think I've ever stopped riding. From what I've read on here, some see low 400 ET's on a regular basis. One of the most consistent ways for me to achieve those temperatures is at continuous highway speeds with my feet back on the passenger pegs. I usually just move my legs back to the regular pegs and watch the temps drop to more normal levels. Only once do I think I saw temps even close to that in stop and go traffic (but I tend to avoid traffic when at all possible).
BTW - If you read other forums, disregard anything you read about BT's and their ET's. The sensors on Sportsters are in a much different location and the two numbers can not be compared in any meaningful way.
Old 2nd May 2018
Ok those temps are in-line with what I'm seeing on my dynojet.
If I get stuck in stop/go I swing north of 400 in about 15 minutes. The highest it climbed was 450 but I babied it to a lot to let it cool.
It very well could be poor assembly on my part. It was my first assembly and I had the jugs on/off too many times to count. Fingers crossed its a quick fix and back on the road by next weekend if the parts arrive.
Coincidentally my riding mower also popped its headgasket but its a briggs so should be as simple as the HD .
Old 2nd May 2018
jzink0883's Avatar
jzink0883 jzink0883 is offline
Sportster/Buell Model: XL1200CP
Sportster/Buell Year: 2015
Sportster/Buell Model #2: XLH1200 (traded in)
Sportster/Buell Year #2: 1998
jzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond reputejzink0883 has a reputation beyond repute
201648Rider,
Thanks for making an old retired tech smile. Reps.
jzink0883, '15 XL1200CP, it ain't butt jewelry, it's a ride
Old 2nd May 2018
jzink0883's Avatar
201648Rider,
Began following your posts when you rode to the west coast.
Questions:
- What problems caused you to have to remove the jugs “too many times to count”?
- Which ring compressor did you use?
Old 2nd May 2018
jzink0883,
I'm really itching to get back out there, I'm thinking a trip in June but not on the sporty .
The 1275 kit came with pistons already installed in new jugs.
The first round I installed these on the factory motor, torqued everything down, decided I didn't trust the dealers diagnosis....pulled everything and found a bent rod in the front cylinder, which is what was causing the knock that sent to the dealer in the first place. (my final guess to the cause is that I sucked water riding in the rain, although I was really quick to blame the fuelpak tune).
On the second engine I'm sure I had things torqued down quite a few different times checking squish clearances and just second guessing everything. Its possible i could have nicked or damaged the gasket taking things on/off...and even more possible things just worked loose.
I'm pretty confident I had everything torqued down per Hammers instructions, but I was also pretty confident I put the pushrods in correctly the first time. .
Old 14th May 2018
Finally got around to replacing the head gasket.
Turns out it was leaking right at the oil passage towards the ront of the front cylinder.
Somewhere along the line I lost the top engine mount bolt on this side of the jug. Thinking maybe its possible that could have contributed to the failure otherwise I'm guessing I might have dmg the gasket during install.
Everything seemed torqued down still. Hopefully this one holds up for a bit longer!
Went for a test ride and the hesitation was gone, but its still pretty cool out and we're getting thunderstorms all net week so I'll have to take it on a longer ride in the near future.
