0 Tried starting the bike this morning, batter charged, but bike wont turnover?
Last Post: clc1989
0 JACKHAMMER 570 Cams!
0 Runs rough on highway.
Last Post: Rich L
5 Summer time heat
Last Post: Kbetts
0 NEW CRANK OPTION for 91-03 OWNERS: XR1200/Buell XB Crank Retrofits
0 Air Filter Soaks With Gas
Last Post: Wilkinson949
0 Sportsterpedia Progress
0 1981 ironhead xlh PROJECT
0 Oil Tank Cap doesn't fit right
0 Lacing a 21 inch wheel to a 19 inch hub
0 Hi from NY state
Last Post: brettxlch
0 New Photo Challenge: Show Us Your Bike Next to a Lighthouse!
Last Post: Bama Lee XLC
5 Why Are You Still Married?
Last Post: JaKaL
Last Post: oupa
0 Do people notice your bike?
0 WTF Happened
Last Post: jcn59
0 Spectro STL 75W140
0 Hoo rah for Missouri.
0 stress killer
0 2 into 1 exhaust build
0 Cv carb jet question
mailmanjohn (52), 93customsporty (52), markmopar (52), ironheadTX (48), Austin-W (47), dcarterjr (47), MaX_01 (35)
Old 25th May 2018
201648Rider 201648Rider is offline
Sportster/Buell Model: 48
Sportster/Buell Year: 2016
201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future201648Rider has a brilliant future
Hesitation came back.
While putting the new handlebars I decided to tidy up some wiring. The coil relocation kit I ised causes the signal wires to route dangerously close to the jugs. Turns out it melted theough the insulation and Im guessing this explains my problem. Such is life for the diy.
Old 5th July 2018
Ok so a few lessons learned. The hesitation eventually came back yet again. I ended up relocating the temp sensor too as that was starting to melt the coating on the rear jug.
I managed to trace this to the root cause. It was the coil failing to ground and wiggling. The DK customs kit I put on worked itself loose over time. It wasn't enough to notice if you grabbed ahold of it but when things warmed up it would wiggle freely and I'm assuming this was causing a bad ground. Tightened things up and man what a difference...finally!
Thanks for all the suggestions here.
