0 New member from Santa Clarita, CA
0 Hello from Waipu, New Zealand
0 Old Parts
Last Post: Yakcm2
Last Post: davixlrtt
0 magnetos 101 questions
Last Post: hawgford
0 mainshaft oil leak
Last Post: T_worth
0 ***DK Custom-LIMITED TIME Sweetheart Deals-Save 10% On Select Products***
0 Bratstyle Japanese Influence Bike Photos
0 In PA Or Nearby
Last Post: Wilkinson949
Last Post: Darkseacret
Last Post: lucky23
Last Post: ReddTigger
Last Post: SLW210
Last Post: SLW210
0 A thunderstorm -weather that is
0 What oil temp do you run
Last Post: oupa
0 Frontbrake upgrade - simple and cheap - how to will follow if there's any interest
Last Post: Yakcm2
0 stock modded exhaust vs short shot
Last Post: Bruce
Old 13th June 2018
Smak937's Avatar
Smak937 Smak937 is offline
Sportster/Buell Model: XL50 Anniversary 1200
Smak937 is an unknown quantity at this point
Ok guys, thanks so much for all the tips and ideas & especially the parts links. I am posting some pics of it covered it the arrid extra dry and we saw no oil from the supposed "crack".
He said If you aren't working on it. It's not a Harley lol
Old 13th June 2018
iNSaNeSHaNe's Avatar
Sportster/Buell Year: 1985
Yep, rocker box gasket leaking. Now ya just gotta wash off the antiperspirant ... no sweat ...
Now when you put the rocker boxes together, you will find the gaskets can be a pain to keep lined up and in the groove. There are a lot of different ways to do this, read the stickies.
The way Harley taught us to do it on the bike was to clean both halves of the cover with brake cleaner to remove all the oil.
Then after drying off, get a flat clean surface and starting with the lower cover bottom side, put a dab of cyanoacrylate adhesive ( superglue ) in the groove at all the corners and in the middle of the track then set the O-ring gasket in the groove and lay it Gasket Down on the clean surface you have ready.
Next, do the same to the upper cover and stack it on the lower as if in the bike, with a light weight on it for a few minutes.
Finally , install the lower and upper cover on the cylinder head.
Good Luck,
Shane
Old 13th June 2018
Smak937's Avatar
Awesome! Thanks again. Way better to be a cheaper fix...at least this time haha
Old 14th June 2018
rejeanprimeau's Avatar
Before reinstalling the cover, sand it flat with fine sand paper on a flat surface like an old window glass.
Old 14th June 2018
Toejam503's Avatar
Air-Cooled Forever
I'll bet there was a nice Sigh of relief. Good Luck
