0 Sudden stiff rear brake pedal.
4 Cross Country Prep
Last Post: DirtyHarry68
0 New Hammer Impact Air Intake Powder Coated
0 33.4 fork axle help
Last Post: Bturkey
0 Lost compression?
Last Post: nychopper
0 End of the road for me
Last Post: BSA Bob
Last Post: SteveK
0 TC88A and Raptor shift light
0 Hillbilly Hot Dogs
Last Post: gravydog
0 Intake manifold gasket fitment
0 Carb issues
0 Sportsterpedia Progress
0 Stuck in fist after a spill
Last Post: BSA Bob
4 Occasionally running troubles
Last Post: jcro61
0 My last real nagging problem
Last Post: Keep it running
0 Oil Pump upgrade
Last Post: hotrodbiker
Last Post: wongjohnson
Last Post: Ridneck1986
0 Xl/Buell drag bike parts
0 The country store
Last Post: lugster
0 XR1000 carbs Dellorto
0 1995 Odometer Acting Strange
Last Post: JackFrost71
0 Poll: Hwy Pegs: fwd mount or crash bar mount?
Last Post: NZstu
0 2014 Sportster 48 $5500
Last Post: ChaseN
stevervp, philvet (75), outlawreb (63), rabes56 (62), Bigmatt (60), Beaker666 (54), hippiemwc (54), wumm883c (52), 2wheeltodd (51), israel (46), XRWeasel (44), Stitch (41), Dekooy (35), Titaniumrust (35), Ameri-Deutsch (34)
Old 17th June 2018
darwin-t darwin-t is offline
darwin-t has a spectacular aura aboutdarwin-t has a spectacular aura aboutdarwin-t has a spectacular aura aboutdarwin-t has a spectacular aura aboutdarwin-t has a spectacular aura aboutdarwin-t has a spectacular aura aboutdarwin-t has a spectacular aura aboutdarwin-t has a spectacular aura about
Default Security system
My 2011 48 left me stranded today. It was running fine. Stopped for a few minutes and it wouldn't start back up. I press the start button and nothing happens.
When I turn the ignition on, the red key light comes on 6 seconds later and stays on. When I turn off the ignition, the light goes out. No blinking.
I changed the battery in the key fob.
It does this if the fob is nearby or not.
If I turn on the ignition twice and press the left turn signal 3 times and the right one once, the light still comes on in 6 seconds and stays on.
Same thing if I turn the ignition on and hold both turn signal buttons down
I had a security module with an alarm. I tried my original one in it's place. No change.
What the heck is going on?
Thanks
'74 Ironhead
'11 Forty Eight
Old 18th June 2018
Toejam503's Avatar
Subscribing Biker
Toejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant futureToejam503 has a brilliant future
Did you try disconnecting the bike battery from the bike and wait about 10min. or so, (helps to completely power down all modules), reconnect the battery, turn key on, wait about 15 seconds and hit start. If the red key came on when you re-attached the battery, you may have to wait 30 minutes.
Old 4 Weeks Ago
Thanks
I unhooked it for over an hour. No difference. I am going to call my dealer in the morning and see what they say. I'll report that here.
Old 4 Weeks Ago
They want $100 to look at it and figure out what is wrong with it. Any actual repairs would be on top of that.
Old 4 Weeks Ago
Some more clues. I had the ignition off when I unplugged the battery. As I started to disconnect it, the alarm went off. Once I pulled it off, it stopped, of course.
I tested the codes again - get a U1300 code for P and SP. No Response for the rest (S,t and b.It does not have a tachometer). I didn't have the RUN switch on when I checked them last night.
Old 4 Weeks Ago
Toejam503's Avatar
Subscribing Biker
It's possible your bike doesn't recognize the key fob. Have the fob checked to see if it's working. If not, replace it..either way the fob will have to be reprogrammed to the bike. A manual for your year of bike will have a table for key fob assignment, listed under the security section in the index.
Old 4 Weeks Ago
Toejam503's Avatar
Subscribing Biker
This is the part that tells me the security system doesn't SEE (detect) a key fob. Usually any car dealership or your local HD shop will have a fob tester and will test it for free. If you can't get it to re-assign and keep coming up with the same code (U1300) you'll need a breakout box to continue. There is a video out on 'Fix My Hog'-(YouTube) on how to use a breakout box and Explains what to test for. I hope this helps you.
Old 4 Weeks Ago
Thanks.
The thing about the key fob is even if it isn't working, I should be able to override the security by inputting the pin with the turn signal switches. The only thing I can think of there is if the fob is bad AND it lost the pin, then I can't input the pin without a working fob. Just an idea.
I'll probably just bite the bullet and take it to the dealer. I am going to call a local independent shop tomorrow. They are closed on Mondays.
My life savings is $1000, so I could easily lose half of it if I take it to the dealer. I'm retired and make just enough to get by, so this is going to hurt...
I should probably just sell it and spend some of the money to fix up my Ironhead. I don't ride much these days anyway.
Old 4 Weeks Ago
Toejam503's Avatar
Subscribing Biker
Never lose faith.
Old 4 Weeks Ago
Dave L's Avatar
Dave L Dave L is online now
Sportster/Buell Year: 1985
Sportster/Buell Year #2: 1985
Other Motorcycle Model: Kawasaki Vulcan 700
Other Motorcycle Year: 1985
Dave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant futureDave L has a brilliant future
That's happened to me with my car. Skin didn't read the chip in the key. Gives you 3 shots like an ATM then shuts everything down. I disconnected the battery. It worked but not sure if that's what really fixed it
