0 Do people notice your bike?
5 '77 ironhead fork neck cup conversion internal steering stop
Last Post: Slytat
0 Spectro STL 75W140
Last Post: DéDé
0 2 into 1 exhaust build
5 Why Are You Still Married?
Last Post: oupa
0 How do you upshift?
0 Hoo rah for Missouri.
0 03 sportster front muffler Stud nut Thread size?
Last Post: gravydog
0 Floppy kickstand spring issue, 1991 model
Last Post: ReddTigger
0 Cv carb jet question
0 900 dual carb front head
0 exhaust or cams?
Last Post: wrkdWS6
0 Oil Analysis?
Last Post: Bwf347
Last Post: oupa
Last Post: Four Speed
Last Post: spacecoast
Last Post: 83XLX
0 The Multi-tool thread
Last Post: gpydeski
0 S.Y.B. Next to a waterfall.....
Last Post: Lone Rider
0 new heads
Last Post: gpydeski
0 Runs rough on highway.
Old 19th June 2018
darwin-t darwin-t is offline
darwin-t has a spectacular aura aboutdarwin-t has a spectacular aura aboutdarwin-t has a spectacular aura aboutdarwin-t has a spectacular aura aboutdarwin-t has a spectacular aura aboutdarwin-t has a spectacular aura aboutdarwin-t has a spectacular aura aboutdarwin-t has a spectacular aura about
I thought I had it fixed. I figured out how to bypass the security system by bending up a pin on each of those relays in the fuse box. I connected them to ground. The ECM and TSSM grounds those pins when the security is clear, which activates the coil in the relay and that closes the switches. One is for the starter and the other is for the fuel pump. It cranks and starts, but it won't stay running. The fuel pump runs, but never shuts off. I wonder if it isn't actually pumping any gas...
I can't see why it isn't working unless the ECM has another signal that does something else. I'll look at the pinouts and see if I can figure anything else out.
'74 Ironhead
'11 Forty Eight
Old 19th June 2018
Toejam503's Avatar
Air-Cooled Forever
TSSM Security Module Resetting Procedure.
For 2001 and up Harley Davidsons with TSSM Security Module, (key icon displays when key is turned to ignition position)
if your security light stays on for a prolonged period of time, if you have changed your battery or disconnected your battery when fitting components such as LED turns & if you have fitted LED turns without a load equalizer, you will need to reprogram your OEM Module.
text in red below step procedure is confirmation of action, always wait for confirmation before hitting the next step:
step # 1. move handle bar kill switch to off position
step # 2. turn your ignition key: on-off, on-off then on
step # 3. hit the left turn signal twice.
your turn signals and indicator light will flash 1 - 3 flashes
step # 4. hit the right turn signal once.
turn signals and indicator light will flash once.
step # 5. hit the right turn signal once.
turn and indicator signals will flash twice.
step # 6. hit right turn signal once.
turn and indicator signals will flash three times.
step # 7. hit left turn signal once.
turn and indicator signals flash to indicate error code
(see error code thread)
step # 8. to now clear codes, hit left turn signal and hold down for 6 seconds until confirmation.
turn and indicator signals flash twice.
step # 9. turn the ign switch to off
Thats it, TSSM is now reset and ready to roll
Try this and if it doesn't work I have another procedure to try, good luck
Old 19th June 2018
Toejam503's Avatar
Air-Cooled Forever
Harley ECM Password Learn
Harley ECM Password Learn Procedure
When installing a new ignition or ECM on a security-equipped Harley there is a “Password Learn” procedure that must be performed. This applies to all Twin Cam and V-Rod models with factory security but may also apply to Twin Cam’s with EFI. The TSM/TSSM and ECM have “learned” passwords that synchronize the control module with several other components. Once you remove a component from this chain the module shuts down and won’t start. This is reported to only occur with EFI models but the new 2004 carbureted models demonstrate the same shut-down when changing the ignition module. Once you have installed the ignition module and reconnected the battery, perform the starting sequence as normal. The engine will cough once in an effort to start but will fail when the module shuts off the fuel. Special Note: During the Password Learning procedure the ignition will remain in the “On” position for an extended period of time (30+ minutes). While “On”, power is supplied to the headlight thus draining the battery. If the battery charge drops below a certain level during the Password Learn procedure the process will cease and you will have to start over. To avoid this connect a trickle charger to the battery throughout the procedure. Download the Password Learn procedure in PDF for printing.
Step Action Confirmation Notes
1 Set Run switch to Run – –
2 Turn Ignition key On-Off-On-Off-On-Off-On and then toggle the Left Turn Signal switch twice. – –
3 Turn Ignition key Off-On Verify the Check Engine lamp and Security Lamp illuminate briefly and then turn off. Security lamp will not illuminate on non-security (TSM) Twin Cam models.
4 Attempt normal start one time. Engine starts and stalls immediately. check engine lamp stays on. Password has not been learned and sets trouble code P1009, thus stopping fuel flow.
5 Wait 10 seconds Security Lamp remains lit for V-Rod and TC88 with TSSM. Lamp will not be on for TC88 TSM models. ECM enters Password Learning mode for 10 minutes. Do Not cycle the ignition or disrupt power.
6 Wait until Security Lamp turns off or a minimum of 10 minutes has passed. – –
7 Quickly (within 2 seconds) turn Ignition key OFF-ON Security Lamp remains lit for V-Rod and TC88 with TSSM. Lamp will not be on for TC88 TSM models. –
8 Wait until Security Lamp turns off or a minimum of 10 minutes has passed. – Password Learning mode for 10 minutes. Do Not cycle the ignition or disrupt power.
9 Quickly (within 2 seconds) turn Ignition key OFF-ON Security Lamp remains lit for V-Rod and TC88 with TSSM. Lamp will not be on for TC88 TSM models. –
10 Wait until Security Lamp turns off or a minimum of 10 minutes has passed. – Password Learning mode for 10 minutes. Do Not cycle the ignition or disrupt power.
11 Quickly (within 2 seconds) turn Ignition key OFF-ON Security Lamp light and then turn off. Lamp will not be on for TC88 TSM models. –
12 Turn Ignition switch OFF . Wait 15 seconds. Turn Ignition switch ON and start engine to confirm the Password Learn Procedure is successful. Engine will start and remain running. If engine immediately stalls and fails to restart the procedure was not successful. Start over at step 1. –
The above steps must be timed and performed exactly as described. Any deviation will require you to start again from step 1.
View printable copy of Password Learn procedure. Enjoy the Ride!
Share on: Twitter, Facebook, Delicious | Permalink
Articles
Here is the other procedure. Put your pins back the way they were first.
Old 19th June 2018
Unfortunately, neither one worked. I get no response at all, I both 20 or 30 times.
The turn signals don't work and I can't turn on the emergency flashers either.
A local shop has disabled the security on another Sportster so they have it now. They say it will be about 2 weeks before they can get to it. I'll update this when I hear from them.
Old 20th June 2018
Toejam503's Avatar
Air-Cooled Forever
Well, let us know what was done, I'm sure their are a lot of folks who would like to eliminate the security feature on their bikes. A lot of people don't realize that all the modules on a vehicle work together or use one another to complete a task (i.e. left turn signal, starter, low beam headlamp). You remove one module and either nothing works, or something you wouldn't associate with the removed module doesn't work right.
Old 4th July 2018
It is fixed!
After I bought it, I purchased an alarm for it, complete with a pager. In doing so, I replaced the security/turn signal module.
That new security/turn signal module went bad. The reason my original module did not work was because the second module was paired to the bike.
They put the original module in, programmed or paired it to the bike and that was it. $35.
When I was picking it up, I asked the guy "So it still has security, but no alarm, right?"
He said "I don't know if he programmed the security in or not. You can do it either way".
I no longer need a key fob! He programmed it without the security.
So I guess Harley dealerships or independent shops with a programmer can simply program the security away very easily. I'd be interested in hearing if they can do that or not.
Thanks for all of the help, everybody!
