0 gas tank paint protection
0 whats your iron head worth
Last Post: Scott
0 If you don't bring closure to your thread, then the terrorists have won
0 Winter reading........
0 THE Trainspotting Thread
5 Run/Turn/Brake light problems
5 Terminology Sticky?
0 Sign of getting old...
Last Post: Firehawk
0 12" or 14"? (Apehangers)
Last Post: Nrg2brn
Last Post: oupa
0 Mainshaft- What happened here
Last Post: moparnut360
6 Is Your SPORTSTER...
Last Post: Kbetts
Last Post: oupa
0 Frontbrake upgrade - simple and cheap - how to will follow if there's any interest
Last Post: Yakcm2
0 How much should I offer for this 48
pwssr, petefwa, skeeter883 (67), roadogette (66), khaskins (61), iriegnome (54), sportster808 (51), ironheadmax (49), matt275 (44), DJb (43), HDFirefighter (37)
Old 2nd July 2018
r4fthrs's Avatar
r4fthrs r4fthrs is offline
Optimist with experience
Sportster/Buell Year: 07
r4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond reputer4fthrs has a reputation beyond repute
Default Starter bolts- to locktight or not to locktight that is the question
OK, halfway through my installation of my new All Balls starter and have some angst about the starter bolts that are inside my primary. The manual says nothing about using locktight, the bolts don't appear to have been originally treated, but it makes me nervous due to how close the one bolt is to the starter gear.
I have torqued to specs., but the snakes in my head are saying I should have used locktight. I don't usually get overly paranoid, but I am an optimist with experience (i.e. pessimist - family motto is: If it were not for bad luck we would have no luck at all). Thoughts????
Armed you are a citizen, unarmed a subject.
Fear the government who fears your guns.
An armed society is a polite society.
Old 3rd July 2018
Blue Locktite is not going to be a problem - Use it if it makes you feel better... Be sure the bolts & holes are clean...
2 Relax
Old 6th July 2018
Murgatroy's Avatar
Murgatroy Murgatroy is offline
Sportster/Buell Model: XL883N
Sportster/Buell Year: 2016
Murgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to allMurgatroy is a name known to all
I use Blue Locktite on any bolt that goes on my bike. I lost my shifter linkage rolling down the interstate once. That was the only lesson I needed.
Old 6th July 2018
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
When in doubt, use blue locktite.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 6th July 2018
iNSaNeSHaNe's Avatar
Sportster/Buell Year: 1985
The Harley guide to lock-tite .
If it vibrates and in doubt use blue,
if it still comes loose use red,
if red doesn't hold use green,
if green fails just weld it.....
