pwssr, petefwa, skeeter883 (67), roadogette (66), khaskins (61), iriegnome (54), sportster808 (51), ironheadmax (49), matt275 (44), DJb (43), HDFirefighter (37) |
24th June 2009
Posts: 5,209 Sportster/Buell Model: 1200N Sportster/Buell Year: 2007
Battery cover popping open while riding??
Well last year when I was riding if I hit a bad hole or bump (Nightster suspension) my battery cover would pop open. Well now I have crammed more junk under it so it pops open all the time. First I was going to use velcro on the inside but after thinking about it for a while I realized that it could still open up. I decided to do this....someone else may have done this before but I already took the pics so might as well do a write-up.
Here is the front clip that keeps letting my cover fly open. I took a small drill bit (less than 1/8" dia.) and made a series of holes and then used the drill to make all the holes one big slot:
I was originally going to use a plastic covered piece of metal to slide in the slot but the slot wasn't wide enough, so my other thought was to use a clipped piece of zip-tie. I left the clipped end about 2-3" long so that I could slide it in and not worry about it working its way back out of the clip:
Here you can see how the slot in the clip coordinates with the slot in the battery cover:
Here is the cover installed and the zip-tie inserted:
Here is a final pic with the stock seat installed:
I have not taken it for a ride, but I can not pull the cover open with my hands without the bike wanting to tip!
Cosmo
24th June 2009
Posts: 4,590 Sportster/Buell Model: XL 1200 R Sportster/Buell Year: 2007 Sportster/Buell Model #2: Buell Uly (sold) Sportster/Buell Year #2: 2009 Other Motorcycle Model: 2010 Ural Patrol(sold)
Good idea, I've used the same one for a couple of years with no further problems
24th June 2009
Posts: 378 Sportster/Buell Model: 1200c Sportster/Buell Year: 2007
Yep...mine does the same thing...goin down the freeway at 75 and go over the bridge seams....it pops open everytime....Great pics and descripton Cosmo...thanks a trilli....
"Four wheels move the body....Two wheels move the soul"
If you feel right about something, than go for it...if you go for it, then you feel right
Eat...Poop...Play.....Sleep....Repeat....
24th June 2009
Posts: 1,221 Sportster/Buell Model: XL883L chopped & dropped Sportster/Buell Year: 2007 Other Motorcycle Model: 1600 cc Volcan Classic Other Motorcycle Year: 05
excellent...i do something similar but this is a pretty smart idea
Ride Safe Eli !
Bought and paid for!
Chop, Drop, and Roll
Tankslapper of the Heavy Horses MC
24th June 2009
Thanks guys & Pork Chop. I know some people zip-tie the cover directly to the frame and even leave the clip off and go hole to hole with a zip-tie. Problem is, if you want to open the battery cover you have to cut the zip-tie and install a new one. By doing what I did, you just pull the zip-tie out, open the cover, close the cover and insert the zip-tie.
All I know is that is going to be nice to finally ride without tapping my hand behind my leg to make sure the cover is still in place after hitting a bump in the road.
24th June 2009
Posts: 35 Sportster/Buell Model: 1200c Sportster/Buell Year: 2008
paint
For those of you that have had their battery cover pop off and hit the pavement i can repaint one cover or both oil tank and bat cover for a good price.Turnaround would be about 7 to 10 days depending on how bad they are messed up.PM me if you have a need for this service.Jason
24th June 2009
XLF LIFEMEMBER Im retired
Posts: 14,324 Sportster/Buell Model: XL50 0596 Black Sportster/Buell Year: 2007 Other Motorcycle Model: E-Glide Other Motorcycle Year: 2003
I drilled a hole in the top of my cover and use a zip tie around the frame.
24th June 2009
Bob F...you would be the one I was referring to. I remember someone did that but couldn't remember who. That was going to be my next step if this didn't work out.
24th June 2009
Posts: 191 Sportster/Buell Model: 883 Iron Sportster/Buell Year: 2009
I knew about this trick but couldn't picture how it looked like. Thanks for the photos!
24th June 2009
Posts: 645 Sportster/Buell Model: 1200XLC Sportster/Buell Year: 2009
Cosmo, that's a nice solution you've worked out I had the same problem a couple of weeks ago and haven't had time to sort through it. Thanks for thinking this up and sharing. I'll use it.
