0 Hello from the Netherlands!
0 Khk flywheels in my ironhead....timing
Last Post: vonhatch
0 Cv carb jet question
Last Post: Bob F
0 Harbour Freight jack
Last Post: Bob F
0 Safety Announcement; Re: Saint Patrick
0 900 dual carb front head
0 Gotta Start a Thread for the Streetfighter Too!
Last Post: Bryan83taco
0 Replacing Stock Sealed Beam Headlight in my 1991
0 Air Filter Soaks With Gas
Last Post: 83XLX
0 Replace crank bearings
Last Post: Maxdog2
Last Post: Four Speed
0 Tacho Ratio's
0 VOES Switch on CV carb conversion.
Last Post: BlackAce
0 HD 100th Anniversary Sporty Pic Thread
Last Post: MoneyFor
0 LED turn signals problem?
Last Post: Scuba10jdl
0 Lets see your Forty Eight's
Last Post: TonyGall
0 XB12 Heads on Wiseco Big Bore Kit
Last Post: sschratt
Last Post: 83XLX
0 1980 Sputhe Sportster
Last Post: chevelle
0 Mikuni HS40 flatslide
0 A Day in the Life...
drifter44 (75), Streak70 (71), Rayzer (61), ridefree1 (57), erk (53), LOBO (51), motley79 (40), polaris0352 (38), TManos916 (38)
Old 25th June 2009
vwcampbell's Avatar
vwcampbell vwcampbell is offline
vwcampbell is on a distinguished roadvwcampbell is on a distinguished road
i will get some info today for you guys...
Old 25th June 2009
Cosmo Kramer's Avatar
Sportster/Buell Model: 1200N
Originally Posted by ShaneD View Post
I ride an 08 Roadster, and I've had my battery cover pop off this spring when I hit a large pot hole. I replaced the front clip and when re-installing the cover noticed a more pronounced "snap" into place than I had with the cover and the original clip. No troubles since....
I have had 2 that used to "snap". The first one I lost as it fell victim to the other problem with these clips (popping out of the frame). Over the winter I have opened, closed, removed, reinstalled, etc. my battery cover probably a million times while rebuilding the bike....I think that is why it became so bad recently. If you open and close your cover often (as I do for the battery tender - no room to permanently hook wires up so just a plug sticks out) then I think you will run into this problem. Unless you have the newer clips that VW is talking about.
Cosmo
Old 25th June 2009
Recon Dad Recon Dad is offline
Sportster/Buell Model: 1200L
Recon Dad has a spectacular aura aboutRecon Dad has a spectacular aura aboutRecon Dad has a spectacular aura aboutRecon Dad has a spectacular aura aboutRecon Dad has a spectacular aura aboutRecon Dad has a spectacular aura aboutRecon Dad has a spectacular aura aboutRecon Dad has a spectacular aura aboutRecon Dad has a spectacular aura about
Originally Posted by 24inchapes View Post
ever wander why harley has so many problems ? i really hate buying a new bike and having to fix it, i dont mind tearing it apart to modify it, but when the factory makes junk it makes me second guess my purchase. battery door, dead batteries, belt guard installed wrong at factory, wiring easily torn out by tire (nightster) kickstand issues, crappsy suspension. but after all thats fixed i love it, just hate fixing a 10k bike.
Don't forget the fuse box, relay corrosion problem. They don't have a permanent fix for it yet.
Patriot Guard Rider Pa. Ride Captain
2009 Heritage Classic Softail, 2008 XL1200L
Old 25th June 2009
roadie996's Avatar
roadie996 roadie996 is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: K&N PCIII Shortshots
Other Motorcycle Model: Ducati 996
roadie996 is on a distinguished roadroadie996 is on a distinguished road
My cover does this too, my cousin works at a HD dealership, I'll see if he can get the part number for the new clips too
Old 25th June 2009
grindbastard's Avatar
grindbastard grindbastard is offline
Sportster/Buell Model #2: xl1200c
Sportster/Buell Year #2: 2005
grindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the roughgrindbastard is a jewel in the rough
I tossed those plastic clips and use zip ties. If I need it open I just clip the ties, and I always carry extra.
gb
"...they mostly come at night......mostly."
2005 XL1200R - Arlen Ness Big Sucker AC, Cycle-Shack slip-ons, #185 Main/#45 Pilot, DynaTek Dyna 2000 Ignition, Forward Controls, 12" air shocks
2005 XL1200C - Stock as F*#k.
Old 25th June 2009
Originally Posted by Cosmo Kramer View Post
I also wanted to keep away from having to replace the tie strap every time I open the battery cover (which occurs often with the battery tender).
Cosmo,
My battery tender came with a wiring harness which attached to the positive battery terminal and ground post. The other end is a plug which I let hangout of the battery cover a little. That way I do not have to remove the cover every night to hook it up.
Old 25th June 2009
Originally Posted by Recon Dad View Post
Cosmo,
Recon, mine is similiar and before this year I had the pigtail hooked up. But things have changed under my battery cover over the winter:
I am sure I could get it to fit in there....but after just completing the rewiring of my bike I want as much access as possible right now in case something comes up.
Old 26th June 2009
XLRida's Avatar
XLRida XLRida is offline
Sportster/Buell Model: XLC 883
XLRida is an unknown quantity at this point
I read on another forum somewhere that there are some "upgraded" side cover clips that can be supplied by the dealer under warranty.
Still, I like your idea Kramer.
Old 26th June 2009
Thanks XL, yeah a couple in this thread have referred to the new clip design....hopefully someone can post some pics. I am interested in what the redesign is.
Old 26th June 2009
vwcampbell's Avatar
cant find my camera...everything got moved last month.
still looking though...
moonlake
