Last Post: vagrant318
Last Post: myrl883
0 Why do sportsters look small?
Last Post: 45Brit
0 Timing issue
Last Post: shovithead
0 It's a Buyinhead
Last Post: kap
0 79 Engine Rebuild
Last Post: Diogenes415
0 New Guy's '76 Ironhead Build/Chop
Last Post: 60weight
0 900 heads contd..
0 Hydraulic conversion for wet clutch
Last Post: Serious Blac
5 1979 Sportster XLS Problems
Last Post: 60weight
0 Push Rod Adjustment
Last Post: sltm1
0 ‘68 XLCH...transmission
Last Post: DirtyHarry68
Last Post: Nate.evans
Last Post: tigger
0 Anyone make a DIY vibrating tumbler?
Last Post: tigger
0 Sportster security help
0 what tool do you use for this starter bendix screw
Last Post: sleighcrane
0 sommer shootout
Last Post: the cowboy way
0 HAMMERPerf 90" In the Works
Last Post: MatHormell
Last Post: jammantoo
0 Laconia Motorcycle Rally 2018
0 My Experience With Phat Performance
Last Post: Skuzeee
0 Galled front piston
0 Bitwell races a 883 Sportster in the mexican 1000
Last Post: hexnut
sflier, dubi1946, unclesumo (61), 81ironsporty (59), cheyenne71597 (58), akk (58), MDRide, JohnK (54), 86stang (53), Dusty1985 (33), evokid8 (27)
  #40471
Old 11 Hours Ago
Old 10 Hours Ago
Graywolf
Old 9 Hours Ago
Old 7 Hours Ago
trainman's Avatar
trainman trainman is offline
Old 5 Hours Ago
LLOYD883's Avatar
LLOYD883 LLOYD883 is online now
Sportster/Buell Model: xl883c
LLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud ofLLOYD883 has much to be proud of
Is that a Chord ?
2005 883XLC - 42 slow jet, 2 1/2 turns out - N65A needle shimmed 0.030" with stock 170 main jet - 07 1200 W cams - mildly ported stock heads - Arlen Ness Big Sucker air cleaner with HD round nostalgia cover - Khrome Werks 3" tapered slip-ons - SE 1200 ignition module - microTach - Mustang "solo tripper" seat - 12 1/2" Progressive 412 chrome rear shocks.
Old 3 Hours Ago
