0 starting rollers
Last Post: ronccc
Last Post: wongjohnson
Last Post: 45Brit
0 carbs?
Last Post: 83XLX
0 Tools
0 -65A mufflers
0 Name that leak
Last Post: gconnsr
0 KBS tank sealer
0 MS rollers way too tight
0 Stuck #2cam
0 A little MARKET RESEARCH on Skid Plates
Last Post: Marsikus
0 Brake light issues
Last Post: 45Brit
0 Diaphram pressure plate
0 Newbie
Last Post: BitterOldMan
0 50 years of wins, the XR750
Last Post: rocketnorton
0 Zippers 1250 kit
0 100 vs 110 front tire
0 82 XLH struggling for power
Last Post: darkgizzard
phantom, JaggedEdge (74), toe (60), john428 (60), testuser (56), rbuier (45), Insane (43), hdtech237 (40), overland47 (39)
  #121
Old 20th May 2013
HybridMomentsPass HybridMomentsPass is offline
Sportster/Buell Model: Buell S3 / Buell 1125R
Sportster/Buell Year: 9908
Other Motorcycle Model: Kawasaki KLX140L
Other Motorcycle Year: 2008
HybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura about
red bike
1203cc
11.50 @118mph, 1.60 60'
black bike
1125cc
11.00 @ 135mph, 1.79 60' (i leave real easy on this bike)
https://www.youtube.com/user/garrettxowens 99 Buell S3 - drag / 08 Buell 1125R - street
Old 22nd May 2013
Jarhead07 Jarhead07 is offline
Sportster/Buell Model: XL1200cx
Sportster/Buell Year: 16
Jarhead07 has a spectacular aura aboutJarhead07 has a spectacular aura aboutJarhead07 has a spectacular aura aboutJarhead07 has a spectacular aura aboutJarhead07 has a spectacular aura aboutJarhead07 has a spectacular aura aboutJarhead07 has a spectacular aura aboutJarhead07 has a spectacular aura aboutJarhead07 has a spectacular aura aboutJarhead07 has a spectacular aura aboutJarhead07 has a spectacular aura about
ive got to lower my 60fts. yall are killin them. if i try and leave that hard she just stands up.
1250 buell Xb heads 15deg squish, .497cams, patriot defender 11.244@117.41mph
Old 22nd May 2013
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
Good to see you back on here! Try melting the clutch a little and hang over the tank as much as possible, put more air pressure in if the bike is standing up. Go get it!
Old 22nd May 2013
Waiting on axle parts. Somehow managed to twist the adjuster and had to cut the axle out. Luckily I was just making a shake down ride after some weight reduction and chain conversion
edit
as a note I ditched the fwd controlls for rear sets and was amazed at how heavy all the componits were. also scored a superlow 17" rear and replaceing the 1" solid axle with a hollow 25mm axle first track outing should be next friday may 31st. i hope the scales are working so i can see the overall savings, and going for 11.5's. last outing i hit 11.7"s but missplaced my slips so those dont count.
Old 23rd May 2013
see if this works
Old 23rd May 2013
madnss's Avatar
Nice slip jar!!!
Old 23rd May 2013
madnss's Avatar
Drop that 60' and youll be dancing in the 11.50 club!
Old 23rd May 2013
madnss's Avatar
Originally Posted by HybridMomentsPass View Post
red bike
1203cc
black bike
1125cc
Gota have a slip, o.p. rules
Old 23rd May 2013
thats the plan waiting on a sleeve for the wheel so i can get back out there.
Old 23rd May 2013
chrisp250r's Avatar
chrisp250r chrisp250r is offline
Sportster/Buell Model: xl1200l
chrisp250r is a name known to allchrisp250r is a name known to allchrisp250r is a name known to allchrisp250r is a name known to allchrisp250r is a name known to allchrisp250r is a name known to allchrisp250r is a name known to allchrisp250r is a name known to allchrisp250r is a name known to allchrisp250r is a name known to allchrisp250r is a name known to all
nice, knocking on my door!!! im gonna have to do better this weekend for sure now...
