0 Tools
Last Post: bklyngeezer
0 Zippers 1250 kit
0 A little MARKET RESEARCH on Skid Plates
Last Post: Marsikus
0 KBS tank sealer
Last Post: wolfryder
0 100 vs 110 front tire
Last Post: dodgetrucken
0 MS rollers way too tight
0 -65A mufflers
Last Post: RussW
Last Post: david.hanaga
0 Brake light issues
Last Post: 45Brit
0 82 XLH struggling for power
Last Post: darkgizzard
Last Post: jon1966uk
0 Newbie
0 50 years of wins, the XR750
0 carbs?
0 Better Brakes
Last Post: mikethebike61
0 my daily driver
Last Post: 84rzv500r
Old 7th January 2019
ReddTigger's Avatar
Yeah, the stealer has the washers, not the bolts. The washers don't come off the old ones either. Guess I could get the bolts at the hardware store.
maybe, but the tsb that i read while working at harley stated they were to be a matched set..
States I've Ridden in
71.3 hp 70.8 tq
Old 8th January 2019
rocketmangb's Avatar
2489 Screw
6589 Washer
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
60Gunner's Avatar
60Gunner 60Gunner is offline
Yeah, they don't have the 2489. I did pick up 8 of the 6589 tho. Any reason a 1" screw won't work in place of the 7/8"? Will they bottom out?
Oops. Didn't see this. Hmmm. I can't even find them listed at J&P or Dennis Kirk. I hate ordering from the dealer. They take forever to get anything in. Like a week at least compared to a day or 2 delivered to my door.
ReddTigger's Avatar
a good dealer should have these in stock..
60Gunner's Avatar
Well I don't think too much of McGrath HD in Dubuque and they never have anything in stock.
Old 9th January 2019
60Gunner's Avatar
I think George meant 2486 on the screws. Those are 1" and according to the dealer, nothing special about them. Hardware store ones should work just fine. We'll see I guess.
Old 10th January 2019
Scuba10jdl's Avatar
Sportster/Buell Year #2: 1972
Neither of the parts are special. Nearly all HD hardware is standard stuff you can get at a good hardware store or bolt depot.
The washers+screw combo (where they won't come off) is called SEMS fasteners. They're one piece because the washer is not slip fit. It has a smaller ID than the threads.
The new, improved washer is a sealing washer. Those can be ordered anywhere and are usually a combination washer and some sort of rubber or nylon insert that seals on the threads. I use 1/2" sealing washers on my breather bolts that I get by the 10 pack from McMaster.
You can use any setup that fits. I've had great luck with the oid style socket head cap screw, washer, and a copper or fabric sealing washer. The copper tends to work better.
Don't go over length on the screw because they're blind holes and you can blow them out. Make sure they're clean of oil too (for the same reason).
[IMG]http://i.imgur.com/Oe4Ttw0.png[/IMG][IMG]https://i.imgur.com/AFv3AMo.jpg?1[/IMG]
Hippysmack's Avatar
I'll add that some bolts are a special length (non standard).
I've bought stainless or grade 8 from Lowes the next size up and cut them to length with a Dremil with no problems.
60Gunner's Avatar
The stock screws for the covers are 7/8" with captive washers(don't come off). Used with the felt seals. But the updated screws, 2486(used with the 6589 bonded sealing washer) apparently are 1" which is what I got at the hardware store since they don't have 7/8". I'm a little concerned about the extra 1/8". The hole appears deep enough but I'm not so sure about the threads. I could either tap the threads a little deeper or like you said, cut the screws down an 1/8". I think I'll do the latter just to be safe. Snapping one off cuz I ran out of thread would be an inconvenience for sure.
Not sure why a dealer would stock the 6589 and not the 2486 that goes with them. No one else seems to have them either. J&P directed me to the colony set I listed above. Those would look nice but I don't want deal with leaks after the fact either.
Old 16th January 2019
60Gunner's Avatar
Hypothetical question...are these 6589 bonded sealing washers reusable? Say you have a leak and pull the cover. Can you reuse the washers? I would've bought more but they only had 2 more left. Can't hurt to have spares.
Also, I bought a James gasket kit but the stock rubber ones between the rocker boxes and covers are in great shape. I'm going to reuse them and just hang on to the kit in case of a leak. I assume reusing these aren't a problem? Obviously the lower metal gaskets will be replaced.
