0 Head Porting 101
0 at least RDRS
Last Post: RDHenley
Last Post: ZCarFan
0 Powerraythor conversion
Last Post: RDHenley
0 BETTER Brakes for $214
0 roadside belt change
0 Blackstone HyperTek
0 [Ignition}Points in a 2000n evo
Last Post: lostjohnny
0 tubing strength if pressed?
Last Post: JonesL
0 Request for recommendations: Sissy Bar for chopped fender
0 Mild 1250 build thoughts?
Last Post: Ghostdog
0 super b overflow
0 69 oil pump breather timing mark
0 is a buell a harley
Last Post: Coz
2003, 883, backfire
  #31
Old 14th January 2010
FoxsterUK's Avatar
Originally Posted by Jakklz View Post
I have an 04 sporty with a heavy breather, 45 slow jet and 3.5 turns out. Still pops and stumbles when cold. Anybody go to a 48 with the HB?
Once you have eliminated air leaks as a problem I'd put an N65C needle in there. Its slimmer profile makes things richer off idle and will cure your problems.
Fox
I had an '05 1200R.
