0 Cases Full Of Oil
0 New users of Windows 10
Last Post: awesomeduror
0 Sprocket cover with chainsikle rearsets?
Last Post: Jason's Sporty
0 On starting a new thread
0 Loose oil pump feed fitting - 2019 Iron
0 Powerraythor conversion
0 RSD Rear-Sets for '04-'13 Sportsters
Last Post: kobra50
3 Shaky Dave Recovery
0 Deer hunting at stairman's.
Last Post: Bow only
0 Speed
0 gas cap
0 Buy A new battery
Last Post: denguy
5 What year is the most collectible Sportster.
Last Post: denguy
14 TC 88A Chat
0 sportster and a grand
gp9739 (75), danbango (72), andyman1958 (61), 55 Jr (58), Love2FixIt (50), keywan (48), C Dubya (45), CA71xlch (44)
Closed Thread
Old 30th May 2010
gearhead1972's Avatar
gearhead1972 gearhead1972 is offline
Sportster/Buell Model: XLH 883/1250
gearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura aboutgearhead1972 has a spectacular aura about
Default Gear ratio calculators
I found these nice little sites to see what different gears will do for you.
I am going to ask a moderator to sticky them.
http://www.gearingcommander.com/
http://www.qddev.com/demos/sprockets...tratios2.shtml
03 Vivid Black 883/1250, with 04 1200r/XB heads, Andrews N4 cams, Hurricane push rods.040 shorter than stock. Dyna 2000i ignition, Screaming Eagle ignition coil and wires. V&H Straight Shots, Generic tear drop with 3in wide K&N filter, 48 slow, 175 main, NOKH needle shimmed .043. Progressive front springs, 412 rear shocks. ♠ 79.5 HP, 77.96 TQ ♠ ~Kevin~
Old 18th March 2011
radeschultz's Avatar
radeschultz radeschultz is offline
radeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of light
Those are pretty sweet...
There are a few threads with these charts, but if a sticky is what it be, then lets include these as well...
http://books.google.com/books?id=cM9...%20mph&f=false
And this little gem that Shu shared in a similar thread...
http://people.montana.com/~bowman/Sp.../SpeedCalc.htm
Closed Thread
