0 Pop-up gas caps
Last Post: Cablejudge
2 Missing hand control screws
Last Post: Andy56
14 A LED turn signals & load balancer how-to.
Last Post: Fifty150
0 Which Battery?
Last Post: Fifty150
0 i'm being the subject of censorship
Last Post: Fifty150
0 Happy Birthday kkbii!
0 Another oil mist problem & slobber stoppers
0 Having trouble finding bolts
Last Post: Hopper
0 Do people notice your bike?
0 How many racers are left ?
Last Post: drgonzo21
0 primary chain adjuster install 1995 1200
Last Post: Pappa G
0 Battery Fuse Stray Voltage
Last Post: SaddleBronc
0 Troubles with tach, ignition or valve float?
0 HT leads for 79 ironhead ?
Last Post: Uberstorm
0 Issues with Hammer 1275 kit
0 Front Top Motor Mount
0 Best Carb for an Ironhead?
14 Harley-Davidson Sportster S. Right For You?
5 Lefty bearing clearance?
0 Hiccup out carb , tried everything I can think of
0 Extended fork tubes and low speed handling
Last Post: jsandidge
0 Hello from Canada
Last Post: sprink
10 Hammerized 1275 and the bike rips hard!
Last Post: xena
0 Customised a biker Opinel Nº8
Last Post: commando57
Sourmug, UberXY (68), bsndscrn, caput001 (65), thunderrod (58), justdrew (55), wareagle0775 (46), blue (41), hellbilly713 (38), TiBaal89 (37), DWilliam (32)
code, diagnostic mode, sportster 1200, troubleshoot
Old 6th June 2019
Pre CANBus bikes showed the part numbers of the devices too.
True - Because the model years between 2004 & 2013 used the Serial Data Bus to communicate between the intelligent Speedo, Tach, TSM/TSSM and the ICM - Exact same principle - Programmable devices showing their current version number (software/firmware) to be able to verify compatibility...
Old 9th June 2019
I AM GRUNT's Avatar
I AM GRUNT I AM GRUNT is offline
Sportster/Buell Model: Sportster 48
Sportster/Buell Year: 2019
I AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to beholdI AM GRUNT is a splendid one to behold
Thank you.
Sincerely, The Grunt | 2019 Sportster XL1200X
Old 9th June 2019
I AM GRUNT's Avatar
Thank you!
