0 2025 XL Forum Calender
Last Post: Brad
Last Post: Brad
Last Post: Racepres
0 Major update forthcoming
0 1980 hardtail build
Last Post: Danger D
0 Cylinder Date Codes
Last Post: JB in NC
0 Locked up '72
3 Ironhead Pictures Thread
0 Kayla Pruitt or Spouse
Last Post: bplinson
0 Pub/shop mirror
0 Ironhead Exhaust Poll
Last Post: ajsstormer
0 C.O.B.B. Spring 2024
0 Belt Tension
Last Post: bplinson
0 Brand New '78 Sportster
Last Post: Diamond Dave
0 65 xlch
0 Happy Hanukah
bridgestone, tyres
Old 21st May 2023
Dusz Dusz is offline
Dusz
Sportster/Buell Model: XL883L
Dusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond reputeDusz has a reputation beyond repute
Default Tyres For EVO Superlow
This is primarily aimed at UK members.
I have a UK 2013 Superlow. The rear tyre now needs replacing. I currently have Bridgestone Battle Cruise H50 front and rear which I have found very good, definitely better than the Scorchers fitted as standard.
Rear is a 150/60 ZR 17 66W
Front is 120/70 ZR18 59W
There are other Bridgestone tyres but usually they do not include the front and rear in the same model type. The Battle Cruise rear tyre in UK retails for around £210 then add fitting. I will need a front tyre later this year so the cost for the Battle Cruise is a little steep although they are a good tyre.
Does anyone recommend another tyre that comes in sizes for both the rear and front and is available in UK?
Can anyone recommend any tyre suppliers in UK?
Ideally I need to change this tyre within the next couple of days as I have a ride out planned for next Saturday.
Any advice welcome.
Old 21st May 2023
Andy56 Andy56 is offline
Andy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond reputeAndy56 has a reputation beyond repute
You must have the 883 variant?
I have a 1200 and the rear is 150/70 17.
Tyre size calculator shows how different they are - https://www.tacomaworld.com/tirecalc...0r17-150-70r17
I have Avon Spirit ST and doing great so far at around 10,000 miles. Still looks to have plenty of life left.
https://www.avontyres.com/en-gb/tyre...ype=motorcycle
Like you they maybe great tyres but I wasn't going to swing for the Michelins.
Old 21st May 2023
bagster guy bagster guy is offline
Sportster/Buell Model: Super Low
Sportster/Buell Year: 2016
bagster guy is an unknown quantity at this point
I got so sick of my bike eating up back tires I went from the 150/60zr17 to a 150/70R17
Old 21st May 2023
I think the Z rating is for like 140mph plus and a Sportster isn't even capable of that speed. The taller tire will help with your gearing.
Old 22nd May 2023
Dusz
Just ordered a pair of Avon Spirit ST tyres the rear in a 70 profile. The slight discrepancy in the speedo should not be an issue as I normally use the speed indicator on my GPS so I don't have to look down.
Hopefully the rear tyre will be fitted Thursday afternoon. The front still has some life in it so it will be replaced in a few month's time.
Old 25th May 2023
Dusz
Had a new rear tyre fitted today - Avon Spirit ST and then put 100 miles on it riding back from the tyre fitters and then doing a Thursday night chip run. So now it is nicely scrubbed in.
Old 26th May 2023
Nibelungen's Avatar
Always liked rim choice of superlow... her wheels fit the best sport touring radials on the market...
Old 26th May 2023
Yes and no. I'm running these wheels, 18x3.5 front, 17x4.5 rear, on my '17 1200 instead of the spoked (with tubes) OE 16's.
The rear is fine but the front is a bit limiting. Particularly if you think you need matching front and rear tires.
Old 26th May 2023
I came pretty close to going with the Avon tire but I ended up with a set of Pirelli Angel GT's. I think it was a smart move upping the profile of the tire.
