29th February 2016
A Million Facts & Figures
Posts: 10,508 Sportster/Buell Model: XL883 Sportster/Buell Year: 2007 Sportster/Buell Model #2: Buell Cyclone Sportster/Buell Year #2: 1999
Did you have plugs installed when you checked spark?
These crank trigger ignitions need some compression, it's how they determine the cylinder phasing.
29th February 2016
Posts: 32 Sportster/Buell Model: M2 Sportster/Buell Year: 1997
No i did not. Wil try this.
Is it meassured by the MAP sensor?
Thanks!
29th February 2016
Thanks!
A guy at HD once told me it was based on the MAP sensor. But I don't think that's right, I think it's based on compression.
Bottom line, and I've seen this on crank trigger bikes that run perfectly, you remove the plugs and put a plug into it's wire and lay it on some metal to check the spark in the traditional way, and you get none. Whether it's the loss of compression or the loss of manifold vacuum that's causing it, I'm not sure. I suppose I could run an experiment to figure it out, but I'm not that curious.
8th March 2016
Posts: 1,713 Sportster/Buell Model: 883 Flat Track Racer Sportster/Buell Year: 2002 Sportster/Buell Model #2: RIP 1200S Sportster/Buell Year #2: 1999
Any updates?
13th May 2018
Originally Posted by A 4 liter V8 eater
Any updates?
Yess... a little late but still....
Replaced the TC88 for a Thunder Heart ignition. Way simpler setup en fired right up!
30th June 2018
Posts: 4 Sportster/Buell Model: x1 lightning buell Sportster/Buell Year: 1999
hello fishman...thanks for reply, which thunderheart ignition did you use and do you have any more pics of your bike...
