Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Transmission, Clutch, Primary & Secondary Drive
0 2025 XL Forum Calender
0 Locked up '72
Last Post: bplinson
0 Belt tension
Last Post: bplinson
0 C.O.B.B. Spring 2024
0 Brand New '78 Sportster
Last Post: Diamond Dave
0 65 xlch
0 Major update forthcoming
Last Post: bplinson
0 Happy Hanukah
3 Ironhead Pictures Thread
Last Post: Kombi1966
0 1970-71 cylinders
0 Ironhead Exhaust Poll
0 Mosey, where you at?
Last Post: MDT
0 Cylinder Date Codes
0 New tyre
Old 19th May 2016
Truckedup Truckedup is offline
Sportster/Buell Model: 883
Truckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of lightTruckedup is a glorious beacon of light
Default One less tooth front pulley question
This is actually a Buell question , figure I will get more opinions here ...
97 Buell stock 27 tooth front pulley and and 61 tooth rear. 128 tooth belt, axle adjuster is about in the middle of the slot with a loose belt adjustment used on tube frame Buells.
I want to use a 26 tooth front pulley .....Do you think the one less tooth front pulley will have the axle adjuster at the rear limit of travel? Thanks
Old 19th May 2016
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Where you post really doesn't make any difference to how many replies you get. The thread appearing on the Active Threads page is what matters.
On the other hand, if it's posted in an entirely inappropriate thread, how would anyone who's interested in the subject find the thread in future in order to benefit from the discussion.
Folkie
South East England Riders
Old 6th June 2016
The 26 tooth pulley is on ...The rear axle is slightly less than 2/3's of the slot adjustment with the stock drive belt...
Old 30th November 2016
jkinkade jkinkade is offline
Sportster/Buell Model: XLH 88" 2003.
jkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant future
Hope i'm not too late here.
You can use stock belt with the 26 front sprocket. i prefer this gearing myself.
Folkie's Avatar
Brass Nut
Yes, he already said that he did that; it used only about ⅔ of the adjustment slot.
