Keep & Kill
Last Post: fafcpa
....1
18th December 2017
Posts: 45 Sportster/Buell Model: 883/1200 Sportster/Buell Year: 2001
buell slide resting position vs sportster.
I have a buell and sportster 2000 m2 and 2001 sportster. When looking down the guts of the carbs the buell slide sits 3mm above these little notches in the carb body, while the sportster sits flush with them. The last numbers on the sporty carb are 95-a, while the buell is 98-y. The buell is too lean at 1/4 throttle yet rich at 1/4 throttle when the sporty carb is on it. The buell slide has free movement and the height difference is dictated by the carb body. Can anyone tell me what the purpose is for this height difference.
18th December 2017
Posts: 10,028 Sportster/Buell Model: Sportster 883►1200 Sportster/Buell Year: 1994
Have you disassembled the original Buell Keihin CV40 carb?
Have you checked the slide diaphragm? The jet sizes (Pilot & Main)? The Idle Mixture Setting? The needle part number? The enrichener circuit? The float level?
Here's the Sportsterpedia section on the CV40 carbs:
Sportsterpedia - Getting Ready to Tune Your CV40 Carb
I would expect either carb to be tunable to the bike if the carb parts are properly working... But you'll have to disassemble to find out if they are...
Can you post a couple comparison photos? (not photobucket, please)...
IXL
2 Relax
>>>> My Build & Ride Reports Are Here <<<<
Reference the Sportsterpedia
A FREE XLForum collection of technical info & advice
19th December 2017
Riding with Angels
Posts: 22,357 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2006 Sportster/Buell Model #2: XL1200C Sportster/Buell Year #2: 2006 Other Motorcycle Model: 48 "Totalled" By a Douche Other Motorcycle Year: 2012
Are both slides aluminum ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
19th December 2017
worked it out. Its a DT slide. Different parts number
19th December 2017
Riding with Angels
BT ? You mean ?
Or Dynojet ?
