Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE FORUM > Buell Motorcycle Air Intake, Carburetor/Fuel Injection, Fuel, and Exhaust
0 2025 XL Forum Calender
0 Locked up '72
Last Post: bplinson
0 Belt tension
Last Post: bplinson
0 C.O.B.B. Spring 2024
0 Brand New '78 Sportster
Last Post: Diamond Dave
0 65 xlch
0 Major update forthcoming
Last Post: bplinson
0 Happy Hanukah
3 Ironhead Pictures Thread
Last Post: Kombi1966
0 1970-71 cylinders
0 Ironhead Exhaust Poll
0 Mosey, where you at?
Last Post: MDT
0 Cylinder Date Codes
0 New tyre
Old 9th May 2019
Manifast612 Manifast612 is offline
Sportster/Buell Model: Buell x1 lightning
Manifast612 is an unknown quantity at this point
Default 2001 X1 lightning bogs out on me
Hello all I'm new here and have been scowering the forum and the web for a while looking for a solution.
Just got my X1 a few weeks ago from a guy that only road it 3x in the last 2 years. Figured thi gs might be gummed up so I've ran a few tanks of 91 non oxt through it with some injector cleaner to clean it out. Still hasn't made a difference
Has anyone else had this issue?
What did you do to rectify the issue?
Like I said I've looked everywhere and I may have missed this somewhere but I've spent weeks looking.
Sent from my SM-G975U using Tapatalk
Old 10th May 2019
Toejam503's Avatar
Air-Cooled Forever
Sportster/Buell Year #2: 1981
Did you try a new fuel filter? Maybe physically clean the injectors, Too.
Old 10th May 2019
Going after that this weekend
Old 10th May 2019
Toejam503's Avatar
Air-Cooled Forever
Well...Howdy and Welcome from North Dakota! Nice looking bike, best tool in your toolbox is a Service Manual.
Old 10th May 2019
Should I stick to a stock fuel filter or can I get one off ebay?
Also the bogging is not all the time, it's periodic.
Toejam503 howdy. I have the manual and I get the idea I have to start with the trouble codes.
Old 10th May 2019
x1glider x1glider is offline
Sportster/Buell Model: X1
Sportster/Buell Model #2: XR1200X
Sportster/Buell Year #2: 2012
Other Motorcycle Model: Kawasaki H2 SX SE
x1glider is an unknown quantity at this point
Did the P.O. fess up to any mods?
Chances are that the fuel filter needs replacing and injectors need cleaning. Throttle body too perhaps. Ultrasonic cleaning really doesn't get the gum out of small passages, it needs chemicals and pressure. I'd remove the tank and clean it real good a couple times with Sea Foam to loosen and remove any gummy stuff. Any new fuel may loosen up gummy stuff and send it downstream.
I bought my current X1 from a guy who let it sit for 7 years and had to replace those parts plus the fuel pump. And a TPS reset did the trick.
Old 14th May 2019
Update: I tried starting it a few days ago and only one cylinder was working so I shut it down. Called St.Paul Harley and they told me $280 an hour to look at it which is ridiculous, they could've just said they didn't want it. So I reached out to the guy I bought it from to see who he had worked on it. Turns out this guy Chris Nimpsy is the last Buell GURU left in Minnesota down in Fairbault so now it's in his hands.
I'll keep you updated.
Old 23rd May 2019
Well here's what it was. Do to sitting all but still for 2+ years the injectors were all gummed up so all it took was a few pressure cycles with carb cleaner through them and now it runs like the machine it is. Great mechanic saved me a few hundred by fixing instead of replacing. Awesome.
Old 24th May 2019
Toejam503's Avatar
Air-Cooled Forever
One of those "Sigh of Relief" moments! Glad to hear it.
