26th June 2022
Posts: 108 Sportster/Buell Model: Cyclone M2 Sportster/Buell Year: 1999 Other Motorcycle Model: Suzuki SV650 Other Motorcycle Year: 01
Mikuni trouble
I was running at Santa Pod yesterday during my burnout I noticed a fuel leak from around the carburettor, back in the pits I found it to be coming from the brass vent tube just above the fuel inlet, I removed the float bowl and checked the float height....way to high
I adjusted it and tried again now it was still coming out of the small diameter plastic pipe when giving full revs, I put a small cable tie around that and tucked it out sight
Every thing is clean inside the carb and the needle jet
Any ideas or suggestions
It's a mikuni HSR 42
10.52@126.86
Reason: Missing information
2nd May 2023
Posts: 9 Sportster/Buell Model: X1 Lightning Sportster/Buell Year: 2000 Other Motorcycle Model: Aprilia Tuareg 660 Other Motorcycle Year: 2022
Not an expert but if it’s possible to lower the float any further, that might be it. There’s a pretty tall brass pipe that connects to the plastic overflow pipe, so if the fuel level in the bowl is getting that high then that might be it.
2nd May 2023
Posts: 1,042 Sportster/Buell Model: sportster stroker xlch Sportster/Buell Year: 1970 Sportster/Buell Model #2: sportster xlh Sportster/Buell Year #2: 1973 Other Motorcycle Model: 99 inch sportster Other Motorcycle Year: 2003
Wondering if when you do your burnout do you rock the bike side to side or hard launch forward? When checking the float height make sure both floats are set the same. 18mm +/- 2mm.
Any chance the fuel in the bowl is sloshing around and getting into the overflow tube? Last thought is there a lot of vibration that can cause the inlet needle to unseat?
2nd May 2023
Posts: 7,467 Sportster/Buell Model: XL77.2R Sportster/Buell Year: 2006
Check your gas cap vent.
2nd May 2023
Posts: 5,058 Sportster/Buell Model: XL1250c Sportster/Buell Year: 2002
Every time my mikuni has leaked from the overflow or vent it was due to the needle not seated correctly due to either some sort of debris or it possibly deteriorating. I have had it look fine and I cleaned it and it still leaked. Each time it happened I ended up changing out the seat and needle the float bowl pushes up to stop the gas flow and that has fixed my problem.
2002 XL1200C
Back to an almost complete stock engine.
Mikuni HSR 45
Supertrapp supermeg exhaust 20 disk open end, Daytona twin tech single fire ignition 1005s
States I Have rode through
11th May 2023
Thanks for the replies folks
11th May 2023
Posts: 3,319 Sportster/Buell Model: xlch Sportster/Buell Year: 1964 Sportster/Buell Model #2: XLCH IR EFI Sportster/Buell Year #2: 1971 Other Motorcycle Model: BMW K1200RS, Other Motorcycle Year: 2001
Check the condition of the oring on the back side of the needle seat.
