Snippets
....1
30th May 2023
Posts: 155 Sportster/Buell Model: xlh Sportster/Buell Year: 1983 Sportster/Buell Model #2: xlh bobber Sportster/Buell Year #2: 77 Other Motorcycle Model: xlh hartail Other Motorcycle Year: 79
mikuni vm38/9 on a 2001 xlh
probably been asked before but will a mikuni vm38 run any good on a 2001 xlh. i love mikunis. all my ironheads have mikunis
if they can how about jetting?
30th May 2023
Posts: 7,467 Sportster/Buell Model: XL77.2R Sportster/Buell Year: 2006
Check Iron Mick thread, sorry but my tablet is complicated, cannot copy and paste.
Sportsterpedia has good infos also. Check top left to access.
31st May 2023
Posts: 1,046 Sportster/Buell Model: sportster stroker xlch Sportster/Buell Year: 1970 Sportster/Buell Model #2: sportster xlh Sportster/Buell Year #2: 1973 Other Motorcycle Model: 99 inch sportster Other Motorcycle Year: 2003
[QUOTE=wiltybob;5996603]probably been asked before but will a mikuni vm38 run any good on a 2001 xlh. i love mikunis. all my ironheads have mikunis
2001 883?
31st May 2023
Posts: 1,202 Sportster/Buell Model: 883 Evo Sportster/Buell Year: 1989
If the bike is stock it may need nothing.
Modified? Can't tell, may need tweaking.
31st May 2023
sungod - 2001 ...all xlh were 883 as far as i'm aware
31st May 2023
having thought about my last post. i suppose it could have had a 1200 conversion but wouldnt that make it an xl.....yes? no?
31st May 2023
Posts: 11,439 Sportster/Buell Model: 1200s Sportster/Buell Year: 2001 Sportster/Buell Model #2: xlch Sportster/Buell Year #2: 1974
sure it will fit, i ran one on my 1974 fxe. but in hind sight, probably the 40 would have been better. tooting around no issue but a long wot stretch takes longer, the 40 would help.
31st May 2023
mikuni vm38/9 is not a carburetor, it's a VM38 with a specific set of internal tuning parts: pilot jet, slide cutaway, needle jet, needle (and clip position), main jet, air jet.
It's pretty close for many stock H-D engines. How close depends on what was done to the engine among other things).
If you're familiar with the VM you know that acceptable performance may be had with more than one different set of parts. The more time you spend, the closer you get.
31st May 2023
well ok but mine is a vm38 -9 which as we ALL know is a vm38 set up for ironheads and fx's among others
all i asked is would it run on a 2001 sporty. mainly because i have a couple or three lying around and i dont like the stock one.
i'm not interested in performance and how fast i can go. i just want to burble about and enjoy the views and wondered if slapping on a mikuni is a possability
31st May 2023
I believe you can get good results with the right adapter and settings.
Give it a try.
