0 68 XLCH - Insight Plz
0 Bigger rear Pulley
0 Sportster cv carb tuning after upgrades.
Last Post: einheit 13
0 Carby cough
0 Help, Headlight out and fuse thing clicks?
0 Solenoid issue?
0 Resto-Repair 84 ironhead
0 Battery melt down
Last Post: Kbetts
Last Post: Bone
0 Don't drive angry
0 Fi to carb
Last Post: lespaul6
0 Front head gasket leak
Last Post: connorneil13
0 Jims Sprocket Shaft Bearing Installation Tool 97081-54
0 Talk to me about Painting
0 FNG from Oregon
0 Diagnostic code ?
0 Smaller turn signals
0 2007 XL1200L Rocker Box Gasket Replacement-Moving the ignition wire harness
fredstoys, voodoo (51), dstivalet (46), Barnett127 (44), illetrop (41), RideoutKSC (37), xlctobe (35)
  #61
Old 2nd July 2018
barefoot barefoot is offline
Senior Bike Builder
Sportster/Buell Model: XR 750
Sportster/Buell Year: 1972
Sportster/Buell Model #2: RR 250
Sportster/Buell Year #2: 1976
barefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond reputebarefoot has a reputation beyond repute
Originally Posted by mrmom9r View Post
Ditto.
Thre was a fairly well-known trick among the AMA guys ... even a few #1 plates, where they would have two engines with the same serial number.
The rules said you had to ride what you qualified, so if you blew up in the heat you were screwed. Nobody then had a complete spare bike but sometimes, well, a really fast and good repair job could be done inside the windowless van ... and if you were a real racer, hassling someone over a rules infraction would have been considered chickenshit. Beat him on the track was the way it was done then.
That's about as close as I can think to the "spare engine" myth ...
Old 3rd July 2018
Bwf347 Bwf347 is offline
Sportster/Buell Year: 1968
Other Motorcycle Model: FLHR
Other Motorcycle Year: 2002
Bwf347 is a glorious beacon of lightBwf347 is a glorious beacon of lightBwf347 is a glorious beacon of lightBwf347 is a glorious beacon of lightBwf347 is a glorious beacon of lightBwf347 is a glorious beacon of lightBwf347 is a glorious beacon of lightBwf347 is a glorious beacon of lightBwf347 is a glorious beacon of lightBwf347 is a glorious beacon of lightBwf347 is a glorious beacon of light
Thanks magneto and mrmom. I never even consider a pre 70 before researching previous threads and consulting the experts here
Old 2nd February 2019
Originally Posted by DR DICK View Post
this is a nick in the casting pattern that got worse as yrs went by.
I've looked at almost a half dozen pre 70s. All with bad numbers, I found thanks to this forum. Could this be my first legit machine?
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XLRTT
thefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant future
Usually, any serial on an ""as cast"" pad will be legit.
IE if you can see the sand casting pattern on the pad it's OK
Any grinding marks or flattening of the pad will indicate messing about.
This is a bad one, strangely enough used as a good example banner on a site trying to school us on legit serials...
Patrick
Flat Head Forever
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
The #2 and the #1 aren't the correct font either.
ricusa's Avatar
ricusa ricusa is offline
Sportster/Buell Model #2: XLH
Other Motorcycle Model: Fat Boy
ricusa is an unknown quantity at this point
Default 1968 XLCH numbers
I've seen other treads dealing with this just not my particular numbers. First my title says 1968 assembled. Under the vin it has F10AB230. The frame has the 16 47584-58 casting number then on a flat area on the right upper down tube the same number from the title only it looks to me like it was maybe added.? Then on the motor on the left on the case between the cylinders there is also the same number on the pad. Further I checked on the right case next to the oil pump there is the same F10AB230 stamped and looks factory. Could this motor be a dealer purchased part, then someone added the number to the frame to satisfy the authorities? Thanks for any info! Rich. Oh it does have a original magneto.
