0 Help with jacking up my sportster
Last Post: BSA Bob
0 68 XLCH - Insight Plz
0 Bigger rear Pulley
0 Sportster cv carb tuning after upgrades.
Last Post: einheit 13
0 Carby cough
0 Help, Headlight out and fuse thing clicks?
0 Solenoid issue?
0 Resto-Repair 84 ironhead
0 Battery melt down
Last Post: Kbetts
Last Post: Bone
0 Don't drive angry
0 Fi to carb
Last Post: lespaul6
0 Front head gasket leak
Last Post: connorneil13
0 Jims Sprocket Shaft Bearing Installation Tool 97081-54
0 Talk to me about Painting
0 FNG from Oregon
0 Diagnostic code ?
0 Smaller turn signals
fredstoys, voodoo (51), dstivalet (46), Barnett127 (44), illetrop (41), RideoutKSC (37), xlctobe (35)
  #1211
GaryanOdinson's Avatar
GaryanOdinson GaryanOdinson is offline
Sportster/Buell Model: 1984 xlch
Sportster/Buell Year: 1984
GaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really niceGaryanOdinson is just really nice
Originally Posted by ryder rick View Post
I would recommend not removing the left side swingarm bearing nut unless you have to.
I think the race can be knocked out without removing it.
The threads are peened and removing the nut may spoil the threads.
The right side nut can be removed/adjusted with a prepared impact socket.
Grind the face of the socket down flat so the socket gets a good full bite on the nut.
Using a long extension will help you keep the socket square to the nut.
Thanks Rick, Tho i have the 82 and later Fork,It has That Threaded Pivot Plug,Thats what FSM calls it its more like a threaded Bushing with a locating pin that locks into a Boss on the fram, keeps it from spinning when Backing out the Bolt, I gave an Earlier Try with B-Bar and 50 -60 Pounds PSI,I was expecting to see a slight movement,as that swivel pin Boss area, has very small area for ticking back and forth .nothing on that try. im hopeing the heat will break it..
Ah! I did not realize there was a change, I've never owned one or paid attention.
The parts book pictures are not detailed enough to offer any help.
randy3934's Avatar
yep been there, might need 150# torque to break it free, then getting the shaft out is something else, I've resorted to welding a nut that fits my slide hammer on the shaft bolt head and slide hammering it out, the few times I had to do this I was able to grind the nut I welded on and use the shaft after cleanup.
SHAKY DAVE's Avatar
SHAKY DAVE SHAKY DAVE is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 83
Sportster/Buell Year #2: xlh
SHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to allSHAKY DAVE is a name known to all
Originally Posted by iNSaNeSHaNe View Post
Just wanted to let ya'll know I'm still alive.
Not much been happening on the IronHead, some bad JuJu happened to interfere with my livelihood.
I hope I'll be able post pics of progress soon.
glad your back bro and I hope the bad crap has passed
Thank You Randy Your Discription is,One of my pre Job Mental Projection,of how this Job Could Go. I Sit in WOE...The Up part here is. The Nut Head of Bolt,Has a Bit of weld Slag , left behind ,as tho It has been Out Befor. So i'll Keep all updated.
