0 Battery melt down
0 Sportster cv carb tuning after upgrades.
Last Post: Granty
Last Post: Kbetts
0 68 XLCH - Insight Plz
Last Post: xlch68cd
Last Post: Bone
0 Don't drive angry
0 Fi to carb
Last Post: lespaul6
0 Front head gasket leak
Last Post: connorneil13
0 Jims Sprocket Shaft Bearing Installation Tool 97081-54
0 Talk to me about Painting
0 FNG from Oregon
0 Solenoid issue?
Last Post: Gulf Coaster
0 Diagnostic code ?
0 Bigger rear Pulley
Last Post: stikflote
0 Smaller turn signals
0 2007 XL1200L Rocker Box Gasket Replacement-Moving the ignition wire harness
0 Resto-Repair 84 ironhead
Last Post: Robyart
0 Who runs 70wt. oil
Last Post: 72 Ironhead XLH
0 One Year
0 Rear Axle Nut Torque Spec.
Last Post: einheit 13
fredstoys, voodoo (51), dstivalet (46), Barnett127 (44), illetrop (41), RideoutKSC (37), xlctobe (35)
brake pads, drum brake rebuild, rear drum brake
Old 12th March 2015
savagegarden savagegarden is offline
Sportster/Buell Model: Sportster XLCH
Sportster/Buell Year: 1970
savagegarden will become famous soon enoughsavagegarden will become famous soon enoughsavagegarden will become famous soon enoughsavagegarden will become famous soon enoughsavagegarden will become famous soon enoughsavagegarden will become famous soon enough
simeli--thanks for the tip on the bevel, worked out well.
Backing plate:
Old 12th March 2015
More backing plate:
Old 12th March 2015
Drum:
Old 12th March 2015
Old 12th March 2015
Welp, I started on the rebuild and noticed that part 6663HB (washer 9/16 x 1-1/8 x 1/16) never came out of the bike. So that may explain some of the spacing. Gonna pick one up tomorrow and try to rebuild and test how it operates
Old 12th March 2015
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1970
Other Motorcycle Year: 1977
get two.
Old 13th March 2015
Well I got 6 from Home Depot and none of them fit, I'm starting to realize there are stores for construction and for automotive supplies and they're different. Anyway I'm a dingus and ended up finding the washer.
Here are the bearings, they measure out at .47 (.4695) for height. Pic:
Other than the big spacer, that was all that came out of the hub on the brake side. I believe I'm missing the spacer washer between the two bearings, part 41195-63. Unless it's that raised lip on the bearing on the right but I don't think that's it. Anyone know the size of that spacer and if I could find it locally?
Old 13th March 2015
Oh and the axle was not even at all. I used doodah_man's method to measure:
use the rear most edge of the shock eye on the swing arm for a reference to measure to the adjusters to keep the axle even
The brake side measured .77 out from the edge and the other side measure .70. I'm changing out my sprocket from 23T to 21T so will probably have to adjust again but this is even for now.
Wheel spun well, no hiccups from the brakes touch and nothing interfering with spin. Seems like a combination of no-beveling (high spots) on pads and poor alignment. Pulled brake lever down 1 1/4 and it began to engage and eventually stop the wheel so I'm glad where i'm at.
Old 13th March 2015
brianbbs67's Avatar
I have been revived
Parts manual calls for 2 of the washers.
Old 13th March 2015
bsaman's Avatar
bsaman bsaman is offline
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1972
Other Motorcycle Model: BSA Spitfire
Other Motorcycle Year: 1968
bsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to allbsaman is a name known to all
Those washers are used for adjustment. I think if the brake plate is making contact with the drum/sprocket, add a shim. Still rubbing, add another. Still rubbing, something is wrong, start over. If you're friendly with your local shop, they may just give you some. Mine did, but I didn't need any after all.
