0 FNG from Oregon
0 Oil Leak ??????
0 Resto-Repair 84 ironhead
Last Post: Yakcm2
0 Low Profile Scissors Lift
0 How packed is your garage?
0 Diagnostic code ?
0 XR1200 for trail riding
0 Started my chop today!
Last Post: skid_ro
0 Ceramic Wax
0 No spark
0 Who runs 70wt. oil
Last Post: hondo
0 Test for picture
0 Spark Plugs
0 1960 XLCH in the UK
Last Post: lynnx
0 74' XLCH wiring question
11 How much did you spend on accessories in the first month?
ralphy, rpcycle (69), shag (67), roadcapDen (66), oedius (63), Coolride (58), 1965XLCH (54), fingerpie (49), Pacer88888 (48), Smitty001 (42), wiccaboa (42), Homiejaime (34), Popedizzle (31), Moker (17)
brake pads, drum brake rebuild, rear drum brake
  #31
Old 13th March 2015
doodah man's Avatar
Originally Posted by savagegarden View Post
I'm changing out my sprocket from 23T to 21T so will probably have to adjust again but this is even for now.
i just switched from 23t to 20t sprocket yesterday; you can expect to have to re-adjust your rear brake arm setting looser. mine tightened up enough when i adjusted my chain to the smaller sprocket that i couldn't roll the bike.
Old 13th March 2015
savagegarden savagegarden is offline
Sportster/Buell Model: Sportster XLCH
Sportster/Buell Year: 1970
savagegarden will become famous soon enoughsavagegarden will become famous soon enoughsavagegarden will become famous soon enoughsavagegarden will become famous soon enoughsavagegarden will become famous soon enoughsavagegarden will become famous soon enough
Brian are you talking about the rear wheel bearing on the braking side (41195-63) or the washer for the wheel bearing (41205-52)? 41205-52 calls for 1 for bikes 66 & later...
Old 13th March 2015
Fridge's Avatar
Fridge Fridge is offline
Sportster/Buell Model: XLCH/H
Sportster/Buell Year: 1973
Other Motorcycle Model: Road King Classic FLHRCI
Other Motorcycle Year: 2007
Fridge has disabled reputation
I believe he is talking about the 6663HB washer you mentioned in your posted message a while back.
Look back thru the messages for it and his suggestion of getting 2.
God to hear it sounds like you got it all sorted out.
Old 13th March 2015
Ah I see it now, thanks
Mofut Mofut is offline
Mofut is an unknown quantity at this point
Default Did you finally find a solution?
Our 73 Sportster is doing the same thing. We rebuilt it after 40 years of down time. New shoes but drags in one spot. Thank you
sounds like out of round/high spot.have you tried the steps in post #11?
1Scooter 1Scooter is offline
Sportster/Buell Model #2: 2004 XLH1200Custom
Other Motorcycle Model: 2007 FXDB
1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold1Scooter is a splendid one to behold
With new shoes, pull them and check the wear pattern. The shoe ends where the shoes pivot will have the wear marks, which is right where they need to be. Might wanna check the wheel bearings and repack with fresh grease while you're at it. Set the pedal play a little loose as the shoes seat themselves. As the brake wears in tighten up the adjuster nut to take out the play.
Thanks for the info. Didn't know enough to go back and look at previous pages of posts. Will try suggestions. Thanks again
