0 Battery melt down
0 Sportster cv carb tuning after upgrades.
Last Post: Granty
Last Post: Kbetts
0 68 XLCH - Insight Plz
Last Post: xlch68cd
Last Post: Bone
0 Don't drive angry
0 Fi to carb
Last Post: lespaul6
0 Front head gasket leak
Last Post: connorneil13
0 Jims Sprocket Shaft Bearing Installation Tool 97081-54
0 Talk to me about Painting
0 FNG from Oregon
0 Solenoid issue?
Last Post: Gulf Coaster
0 Diagnostic code ?
0 Bigger rear Pulley
Last Post: stikflote
0 Smaller turn signals
0 2007 XL1200L Rocker Box Gasket Replacement-Moving the ignition wire harness
0 Resto-Repair 84 ironhead
Last Post: Robyart
0 Who runs 70wt. oil
Last Post: 72 Ironhead XLH
0 One Year
0 Rear Axle Nut Torque Spec.
Last Post: einheit 13
fredstoys, voodoo (51), dstivalet (46), Barnett127 (44), illetrop (41), RideoutKSC (37), xlctobe (35)
Old 1st October 2015
doodah man's Avatar
Originally Posted by snow View Post
Hey Doodah--- how's your gas mileage with the Mikuni compare to the E?
much better with the mik for me. getting around 46-47 mpg, where i was getting around 38-40 with the super e. i attribute the fuel economy to the lack of a fuel pump on the vm. i could probably squeeze a bit more out of it if i were to baby it, but who wants to do that!?
smokey 2 smokey 2 is offline
Sportster/Buell Model: 1970 XLCH
Sportster/Buell Year: 1970
Other Motorcycle Model: Ultra Classic
smokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of lightsmokey 2 is a glorious beacon of light
I have been running Bendix for years. Adjust the float to stop leaking. The accelerator
pump works great for starting. I wire up the choke, so it is out of use.
WORK TO RIDE, RIDE TO WORK
Heff's Avatar
Heff Heff is offline
Sportster/Buell Model: Xlh
Heff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of lightHeff is a glorious beacon of light
Su.
They don't stick out *that* far
86 xlh
snow snow is offline
Sportster/Buell Model: xlch sportster
Sportster/Buell Year: 1969
snow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant futuresnow has a brilliant future
Loved the SU on my Shovel--- open primary left side, SU right side with that piston going up & down, straight pipes--- set off every car alarm in Brooklyn & Manhattan...
Old 2nd October 2015
brianbbs67's Avatar
I have been revived
Sportster/Buell Year: 1961
Sportster/Buell Year #2: 1970
Other Motorcycle Year: 1977
I think the OP should take the time to fix the Bendix and then decide. Whatever carb is run will need maintenance eventualy anyway.
Heff's Avatar
You know, I've never heard an su piston bounce on a car engine, and I can't hear mine, except at start up.
Don't mean to hijack thread or anything
gpydeski gpydeski is offline
gpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to beholdgpydeski is a splendid one to behold
I did an 80 mile ride on my XLCH last Saturday. It has a super e. It started on the first kick and it didn't miss a beat. With short straight pipes and 5 dollar baffles I have 28 intermediate jet and a 66 primary jet. I get about 38 mpg with this setup. It was hard to get to this final happy medium, a lot of jet changes.
doodah man's Avatar
yes, i can also say i got consistent, reliable starting with my super e. once set up, it's a very predictable carb.
JMAHES JMAHES is offline
Sportster/Buell Year: 1973
JMAHES is an unknown quantity at this point
I had a few different Bendix carbs to play with 20 years ago.Different issues with all of them but I did finally get one to behave for the most part. For me, only two drawbacks: fixed main jet would lose power at high rpm/wot, and the choke would shut itself on the highway when hauling ass for some reason.
It was great on low/midrange power though!
I installed my Super E in 1995 and have rebuilt it once since then. very reliable but a big carb for a1000cc. wot is fun though with this carb.
I like the Super E, not the most efficient carb for this engine but I do run drags so if you whack the throttle, you will gulp air and then blast off.
The Mikuni sounds interesting but my SS is not worn out yet, so if it breaks one day I might just try it
Moon Wolf's Avatar
Moon Wolf Moon Wolf is offline
Sportster/Buell Year #2: 1957
Other Motorcycle Model: KH KHK XLH XLCH
Moon Wolf has a reputation beyond reputeMoon Wolf has a reputation beyond reputeMoon Wolf has a reputation beyond reputeMoon Wolf has a reputation beyond reputeMoon Wolf has a reputation beyond reputeMoon Wolf has a reputation beyond reputeMoon Wolf has a reputation beyond reputeMoon Wolf has a reputation beyond reputeMoon Wolf has a reputation beyond reputeMoon Wolf has a reputation beyond reputeMoon Wolf has a reputation beyond repute
Don't have much to add to the endless carb debate except to add the Super E gets the worst mileage of all the popular carbs by a good bit. They start and run well, though. If mileage is a factor, if for instance you are running the little tank, the CV gets as much as ten miles a gallon more than the others and works well but it is ugly (but then so is the Mikuni in my opinion).
I've never had a Bendix leak. If yours leaks, there is something wrong.
