0 Who runs 70wt. oil
0 2019 xl1200 suspension upgrade
0 1970-71 XL Fuel Tank ?
Last Post: Parker 1000
0 A few more filter options
Last Post: Tucsonmax1
0 Oil Leak ??????
Last Post: ftwflh
0 2010 Sporty will not fire! Tried everything, HELP!!!
Last Post: kxrwcer52
0 TSM / TSSM / HFSM - How to disable alarm and/or replace unit
Last Post: caffieneracer
4 greetings from quarantine!
0 XR1200 for trail riding
0 Low Profile Scissors Lift
0 XL Parts '04 up
Last Post: Jcolleyoh
0 '04+ Starting Issues, Do You Have Them? - Poll
0 1960 XLCH in the UK
Last Post: chilly
0 Intake seals, glad I checked them
0 Sportster Tank Art
Last Post: Bryan83taco
0 Why cafe a sportster?
Last Post: Merch131ho
0 Spark Plugs
Last Post: Joe_jeep
0 74' XLCH wiring question
0 Resto-Repair 84 ironhead
ralphy, rpcycle (69), shag (67), roadcapDen (66), oedius (63), Coolride (58), 1965XLCH (54), fingerpie (49), Pacer88888 (48), Smitty001 (42), wiccaboa (42), Homiejaime (34), Popedizzle (31), Moker (17)
Old 2 Weeks Ago
02vette 02vette is offline
Sportster/Buell Model: XLCR
02vette is an unknown quantity at this point
Default Recommended Keihin Jet Sizes ? - 100% Stock XLCR
Hi guys. Just finished up a nut and bolt restoration on my 1977 XLCR. After an initial 6 mile ride I noticed the following.
Bike idles excellent. Idle mixture screw set a 1 full turn out from close.
Engine seems to bog during while rolling the throttle past 1/4 turn. I'm thinking this is caused by transitioning from the slow speed circuit or jet to the main jet.
Bike is 100% stock except for a Dyna S ignition. Intake and exhaust are the 49 state "loud" setup. Stock P cams. Stock 9:1 compression.
Current jet sizes are 90 slow speed and 175 main. I'm thinking these are a bit on the fat side. Location is Knoxville, TN.
What jets sizes will get me close? Thanks much.
Old 2 Weeks Ago
Quick note about me. I am a retired HDMC employee of 30 plus years. Worked as a Factory Mechanic Tech at both the PDC " Willie G Product Development Center " and at Juneau Ave., Milwaukee WI as a Factory Tech.
Old 2 Weeks Ago
Which carb? If it is the Kehin butterfly with no fast idle, your best option is to grab up a CV or a VM-38-9.
The first gen Kehins are not well thought of. You can fotz with the drill pattern if you are brave and determined. The transfer ports are under the welsh plug in the top of the carb.
Old 2 Weeks Ago
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
Take a look in the Ironhead Tech Stickys Index here http://xlforum.net/forums/showthread.php?t=465866
Theres a thread in there on Tuning Keihins with lots of info.
My 77 XLCH came stock with a 165 main and .75 low speed jet. But the CR has totally different exhaust so may have been jetted different. With a decent air filter and pipes on my CH I run, from memory, about a .85 slow and 175 main.
They are a decent carb when jetted right. Never had problems with mine. Tried a few others over the years, Mikuni VM38 and an Andrews Super 45 Tillotson and ended up going back to the stock Keihin these days.
Biggest problem I ever had with the Keihin was a worn out ignition auto advance unit that caused carb farts off idle. Like they say, most carb problems are electrical.
Old 2 Weeks Ago
You must have gotten a good one, there are some that have a horrible off idle stumble/flat spot and the term KaSneeze became familiar among tuners. Steady state at 60mph and it sneezes.
Just to be sure this is the first generation version with the metal choke arm and no fast idle linkage.
Old 2 Weeks Ago
Hopper's Avatar
Yep that's the one. The 38mm original as fitted in 76-78. The one with the fancy choke arm I think was the 34mm from 79 onwards.
One thing I do is run my intake and exhaust pushrods one flat looser than the factory spec. Helps stop sneezing/carb farts at cruising speed. A new auto advance unit helps stop it at idle and just off-idle. Plus I run both O rings and the later type rubber sleeves over top of them on the intake manifolds to make sure it's sealed up tighter than a really really tight thing. Plus air-filter support bracket to keep manifold straight and sealed.
Old 2 Weeks Ago
thefrenchowl's Avatar
Sportster/Buell Model: KHK
Sportster/Buell Year: 1954
Sportster/Buell Year #2: 1978
Other Motorcycle Model: XLRTT
thefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant futurethefrenchowl has a brilliant future
CVs might be OK if you just plod/ idle about with your bike...
But they kill the high RPM...
Stick with early 76/79 Keihin, not quite on par with Tillotsons, but not far...
My guess is your idle is a tad rich.
Play with the idle screw and the butterfly stop screw till you get a nice idle about 900rpm and get no spit backs when running say in 2nd/3rd gear in both violently opening and closing of throttle...
The idle should also be just fat enough to allow the engine to start dead easy. If struggling on start up, idle mixture is too lean.
Early Keihin came out with 100 idle and 180 main (1mm and 1.8mm), you're not far out.
Last point, make sure you have the idle channel rubber plug fitted at the bottom of the vertical idle channel inside the float chamber: the idle get its gas from the main jet tower, not from the bottom. If the plug is not there, your idle will always be too fat.
Patrick
Flat Head Forever
Old 2 Weeks Ago
Originally Posted by thefrenchowl View Post
... Stick with early 76/79 Keihin...
I do not know about E76 and previous, but late 76-78 Keihin is 38 mm. 1979-on is 34 mm. The 38 mm is the better performing of the Keihin butterfly carbs.
Old 2 Weeks Ago
Hi Mick,
I was thinking all the early Keihin that have an accessible idle screw and a single cable!!!
For sure, Keihins butterfly carbs with no idle adjust screw to be seen and twin cables are bad...
So you are right!!! early 76 were still fitted with Zenith carbs...
Patrick
Old 2 Weeks Ago
Patrick
The idle will be fine it is the main jet that gets bypassed with the plug removed.
This happens because the hole that transfers fuel to the low speed jet is opened to the float bowl with the plug removed, and un metered fuel flows into the main jet passage. It's like removing the main jet (or doubling it's size)
