0 A few more filter options
4 greetings from quarantine!
0 Who runs 70wt. oil
0 1970-71 XL Fuel Tank ?
Last Post: The Doctor71
Last Post: fafcpa
Last Post: SLW210
0 2019 xl1200 suspension upgrade
Last Post: SLW210
0 Diagnostic code ?
Last Post: robbie202
0 Oil Leak ??????
Last Post: ftwflh
0 2010 Sporty will not fire! Tried everything, HELP!!!
Last Post: kxrwcer52
0 TSM / TSSM / HFSM - How to disable alarm and/or replace unit
Last Post: caffieneracer
0 XR1200 for trail riding
0 Low Profile Scissors Lift
0 XL Parts '04 up
Last Post: Jcolleyoh
0 '04+ Starting Issues, Do You Have Them? - Poll
0 1960 XLCH in the UK
Last Post: chilly
0 Intake seals, glad I checked them
0 Sportster Tank Art
Last Post: Bryan83taco
0 Why cafe a sportster?
Last Post: Merch131ho
0 Spark Plugs
Last Post: Joe_jeep
ralphy, rpcycle (69), shag (67), roadcapDen (66), oedius (63), Coolride (58), 1965XLCH (54), fingerpie (49), Pacer88888 (48), Smitty001 (42), wiccaboa (42), Homiejaime (34), Popedizzle (31), Moker (17)
Old 2 Weeks Ago
bill smith bill smith is offline
Sportster/Buell Year: 1971
bill smith is just really nicebill smith is just really nicebill smith is just really nicebill smith is just really nicebill smith is just really nicebill smith is just really nicebill smith is just really nicebill smith is just really nicebill smith is just really nicebill smith is just really nicebill smith is just really nice
Default Hi temp sealer
Has anyone ever used powdered graphite and motor oil mix for an exhaust sealant?
Old 2 Weeks Ago
doodah man's Avatar
I’ve never heard of that mixture before, though that doesn’t mean much. Many of us here use permatex ultra copper for the exhaust pipe/head junction.
https://www.permatex.com/products/ga...-gasket-maker/
Old 2 Weeks Ago
^^^^^^^^^this^^^^^^^^^
Old 2 Weeks Ago
It’s what the factory said to use on the intake pocket of a JD. I tried the hi temp silicone but it didn’t work.
Old 2 Weeks Ago
doodah man's Avatar
How many slots are at the exhaust pipe where it attaches to the head? You could make an extra slot or two to help it clamp down, just don’t make them too long. I did this to mine and also used the “aircraft style” clamps to become leak free.
Old 2 Weeks Ago
JonesL JonesL is offline
Sportster/Buell Model: XL
Graphite and oil/grease is usually used as a stove polish or anti-seize formula. Like the guys say; Modern high-temp sealers w/ copper are a consideration.
Refractory/Firebox cements would certainly work but they set up like mortar, making disassembly a real pain.
But if you're working on a JD with it's screw-in spigots and plumber's nut and copper ring type 'clamps', I'd tend to stick with the factory recommendation and let fresh copper seals do the sealing. Copper can be annealed and reused if the originals aren't torn or broken.
"If a camel flies, no one will laugh if it doesn't get very far".
Old 2 Weeks Ago
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
When I worked in the shop, the old timers there always had a small tub of what they affectionately referred to as “Mad Mix”. If I recall it was ant-seize with a bit of Kendall thrown in. An acid brush was stuck in the cut out lid to use liberally in any sort of scenario. I could definitely see them use it on the JD as I know I saw them use it on the side valve “plumbers” nuts.
Old 2 Weeks Ago
I think I need to explain this better, what I'm workin on is the intake pocket of a JD. I axd about exhaust sealant because I thought more people would be familiar with that than a JD. The 1918 service book sez to use a mix of powdered graphite and oil on the shoulder of the intake pocket. I was just wondering if anyone had any experience with this mix. I have tried a hi temp silicone on the intake pocket but it didn't hold up at all.
Old 2 Weeks Ago
doodah man's Avatar
Some interesting info here
http://www.caimag.com/forum/showthre...14-Inlet-poket
Old 2 Weeks Ago
Can’t help much more on the graphite, but was at the Milw factory museum last Tuesday and took this pic. Quite a display of real iron. Didn’t take many pics of the knucks or pans as they are plentiful, however I did get lots of shots of the real cool old stuff such as your project.
