Last Post: Bow only
0 Solenoid issue?
0 Resto-Repair 84 ironhead
0 Sportster cv carb tuning after upgrades.
0 Battery melt down
Last Post: Kbetts
0 68 XLCH - Insight Plz
Last Post: xlch68cd
Last Post: Bone
0 Don't drive angry
0 Fi to carb
Last Post: lespaul6
0 Front head gasket leak
Last Post: connorneil13
0 Jims Sprocket Shaft Bearing Installation Tool 97081-54
0 Talk to me about Painting
0 FNG from Oregon
0 Diagnostic code ?
0 Bigger rear Pulley
Last Post: stikflote
0 Smaller turn signals
0 2007 XL1200L Rocker Box Gasket Replacement-Moving the ignition wire harness
0 Who runs 70wt. oil
Last Post: 72 Ironhead XLH
0 One Year
0 Rear Axle Nut Torque Spec.
Last Post: einheit 13
fredstoys, voodoo (51), dstivalet (46), Barnett127 (44), illetrop (41), RideoutKSC (37), xlctobe (35)
MotorPete MotorPete is offline
Sportster/Buell Year: 1972
Other Motorcycle Model: Norton Commando
Other Motorcycle Year: 1970
MotorPete will become famous soon enoughMotorPete will become famous soon enoughMotorPete will become famous soon enoughMotorPete will become famous soon enoughMotorPete will become famous soon enoughMotorPete will become famous soon enoughMotorPete will become famous soon enough
Default Plunger Seat on a 72'
Looking for advice. I'd like to install a plunger seat on my 72 xlch. I've read through all the threads on this but am no expert in the machining or frame needs associated.
I'll attach some photos for those familiar, maybe you can't point out if things won't/will work etc... I know there are a few experts on the subject here. Appreciate anything you guys can help with.
Here's the bike, my first Ironhead, put a few hundred miles on the clock during this mild March.
Tubes are 10" deep, cleaned a decent amount of crap out with a magnet. Bored out at the top at 1". Let me know if anything else might help.
Thanks again
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
http://xlforum.net/forums/showthread.php?t=1414910
Had that style when I drove mine home from the dealer, then went to the King/Queen and then to this. From the FX model, fit and comfort improved.
https://www.ebay.com/itm/Sportster-5...wAAOSwZAtXI6-e
Thanks for the info. I'm fairly certain I've got the right frame set up, need to confirm spring O.D. with whomever provides the kit, Thanks. Stay safe and healthy out there.
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
http://xlforum.net/forums/showthread...1834828&page=2
See post #18
Originally Posted by iron mike View Post
thank you mike. I sent mrmom a message earlier to see if he was still selling them, seems he is.
the springs in his kit measure 3/4'' o.d. i had the right tubes but had some casting flash or something in one of them.i needed to run a 13/16'' drill bit down through that one.
Cleaned quite a bit of crap out of mine. Walls seem OK. I've got a few tube brushes on the way, as well as the kit from Don. Hopefully no jumbo drill bits in my future... Thanks for the help.
